Question about Panasonic Toughbook CF-27 Notebook
How to replace hard drive? - Panasonic Toughbook CF-27 Notebook
  • Panasonic Master
  • 8,404 Answers
Open the cover, unplug the device its out.
Get a new one ... plug it in, its out.
There is lots more ... do you know is involved in reloading the OS?
Ask me if you need help
a
Posted on Oct 01, 2009
HD REPLACEMENT
Check if you can use SATA else you'll have to look for IDE
Actually to insert a SATA drive is easier then replace a light-bulc.
Just remove cables, unscrew from "drawer" insrtn new drive, scress, replace cables.
If it's a system disk, the difficulty is resintall your system. After you've replaced Hard disk, formulate your question with more doubts
See some fine videos here
How to install SATA hard drive into computer
How To Install Internal Sata Hard Drive and Activate In Windows OS
How to install and remove SATA Hard Drive
How to Replace Desktop Hard Drive
How to Install Second SATA Hard Drive
Jun 27, 2015 | Computers & Internet
How to replace hard drive in Canon image runner 2230 copier
Replacement Hard Drive (LMXWM25216000) for Canon imageRUNNER 2230
Dec 16, 2013 | Computers & Internet
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
May 20, 2013 | HP DesignJet 1055cm InkJet Printer
Pri master hard disk s.m.a.r.t. status bad, backup and replace press del to resume
Hard drive is bad or is going to fail soon.
Solution
Backup your information and contact the maunufacturer of the computer or the hard drive for replacement or additional help.
In some very rare cases the S.M.A.R.T. implementation on your computer may have issues of its own and may need to be patched before replacing the hard drive.
If I am receiving the S.M.A.R.T. error, is it ok if I continue to use my hard drive and do not replace it?
As stated above, S.M.A.R.T. is designed to detect upcoming failures in the hard drive.
While it is possible that the hard drive may not fail for several months, it is still inevitable that the hard drive will fail.
It is ok to continue to use the hard drive, however, we highly recommend that if you are still under warranty that you consider getting the drive replaced before your warranty runs out.
hope this helps
Sep 20, 2012 | Western Digital WD AV WD2500AVJS hard...
How do I replace the hard drive on my sony Vaio VGN-NR120E?
To replace a hard drive, you'll need to backup any data you want to keep, uninstall the old hard drive, install the new hard drive, and then restore the backed up data.
The specific steps necessary to replace a hard drive differ depending on the type of hard drive you're replacing.
Jun 20, 2011 | Sony VAIO VGN-NR120E/S Notebook
What hardrive for my armada M700?
Hard Drive Installation Instructions 40 gig IDE DRIVE
  1. Shut down the computer and remove Battery Pack and AC adapter.
  2. Locate Hard Drive compartment on the front panel, just left of the head phone jack.
  3. Turn Notebook upside down.
  4. Remove the one torx screw that is securing the hard drive. (A security screwdriver was provided with the computer.)
  5. Push down on the hard drive bezel on the front of the hard drive.
  6. Lift the bezel up 90 degrees to create a handle. Pull the hard drive out of the hard drive bay.
  7. Remove the 4 black screws at each corner and lift off the black tray.
  8. Gently remove the silver bracket and connector.
  9. Place connector on new hard drive.
  10. Place the black tray on the HDD. When looking at the hard drive with the label up, the black bezel goes along the left side of the hard drive.
  11. Replace the 4 black screws from step 7.
  12. With the hard drive bezel pulled down, slide the hard drive into the hard drive bay.
  13. Push up on the hard drive bezel to secure the hard drive in the bay.
  14. Secure the hard drive bay by replacing the screw from step 4.
  15. Replace the battery pack and all cables
Aug 08, 2009 | Compaq Armada M700 Notebook
Can i replace the default hard drive with any brand hard drive?
Well the replacement drive should be the same interface. i.e. if its an IDE drive then you'll need an IDE drive if its a SATA drive you'll need a SATA drive! regards, babb
May 07, 2007 | LaCie (300773) 1638.4 GB Hard Drive
Panasonic Toughbook CF-27 Notebook Logo
214 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
