Question about Panasonic Lumix DMC-TZ1 Digital Camera
Everytime I turn my camera on it says please turn camera off and then on again.It works in playback mode but that is it.
  • 11,896 Answers
The firmware will need to be updated which is really common. You can send the camera in to manufacture and they will do it for $50 or you may get lucky enough to find an update on the web
Posted on Oct 01, 2009
  • 172 Answers
SOURCE: lumix tz3
Low battery maybe? Try holding camera firmly in one hand, with camera on and in record mode, and strike in on its edge firmly on the heal of your other hand. This technique is often sucessful with temporary camer 'quirks' like freezing, lens not fully retracting, etc.
Posted on Apr 05, 2008
JoeO700
  • 80 Answers
SOURCE: Problem - Turn off and turn on again - happens repeatedly
We see this camera often because the lens gets compressed some how and the plastic gears which drive it become damaged, this would be the "buzzing" noise you're hearing during power up. The camera is not passing its power up diagnostics and therefore it shuts down. The lens is not cost effective to replace on this camera, parts and labor exceed a replacement units cost. Hope this is some help. Good Luck Joe Weibel Custom Electronics (customelectronics.org)
Posted on Feb 13, 2007
SOURCE: Hi, I have a panasonic Lumix, DMC-FS5 digital
I had this same problem. I have just pulled the lense (not with any major strength) when it was fully extended. This seems to have solved it for me!!
Posted on Oct 27, 2009
  • 11967 Answers
SOURCE: getting "turn off" message while in camera mode
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 16, 2010
  • 11967 Answers
SOURCE: panasonic lumix dmc-fx100 problem
Posted on May 10, 2010
Panasonic DMC-ZS6 when in camera mode lens comes out and I get the message "Please turn camera off and then on again" when I turn off the lens just stays out.
There is an issue with the camera focus circuit in lens. That is why it is ok when you go into playback mode but negative when the lens is involved.
Aug 25, 2017 | Panasonic Cameras
Hi.i have a really important question and im hoping you can help me.everytime i try to review my videos on my camera it says(video management file is broken to record/playback video,recovery is...
Select "OK" to restore. (Videos that cannot be restored will not be displayed on the index screen, but you may be able to play them back using "PLAYBACK MPG FILE" in the menu.
if the file is damaged....
Select the playback mode.Select video mode.Touch to display the menu.Select "PLAYBACK MPG FILE" and touch.Select the desired video and touc.
May 12, 2017 | JVC GZMS230 Camcorder (Black)
My sony digital cam wont turn on or remain on. please help me. tell me what i should do
  1. Ensure you are using fresh or fully charged batteries. IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
  2. Attempt to turn on the camera.
  3. If the issue is not resolved, try replacing or recharging the batteries if available.
  4. Attempt to turn on the camera in Playback/Edit mode by moving the mode switch to the Playback/Edit mode or by pressing the playback button.
  5. Switch the unit to camera mode and attempt to turn on the camera.
  6. If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet. NOTE: Skip this step if the camera being used does not support the use of an A/C adaptor.
  7. Attempt to turn on the camera.
  8. Remove the Battery, press the power button for 30 seconds.
  9. Please wait for one minute, insert the Battery and turn it on.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. [[]]
Jun 25, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Ricoh Caplio R7 focusing problem
Go into the menu and find "reset"...follow the on-screen instructions.
Feb 24, 2010 | Ricoh Caplio R7 Digital Camera
Canon a610 no display of new pictures only previous
I almost have the same problem.
My camera automatically switches between playback and camera mode quickly only for a while,then it remains still in the playback.When it remains in playback,if I toggle the playback/camera switch few times,it may work for some shots but again the problem begins. (http://www.fixya.com/ThreadAsker.aspx?thid=2918658)
Did you find any solution?
Aug 15, 2009 | Canon PowerShot SD1000 Digital Camera
Shooting/playback mode switch
in the end it was my memory card which suddenly went faulty.after formatting it, (see above added comment) it worked for some pictures then i switched to playback and this time it said memory card error and shut down. well if it would have said this in the first place would have saved a lot of trouble i almost threw the thing away.(the camera) so i puts a new card inside and its working like new, all the playback i can handle. goes to show its not always as bad as it looks with a little patience.....merci
Feb 27, 2008 | Canon PowerShot A520 Digital Camera
Lumix tz3
Dec 31, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Can't take picture
Needs to go back to Panasonic- an inherent fault.
Aug 16, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
641 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
