Question about Frigidaire Refrigerators
CONDENSATION ACCUMULATES INSIDE THE REFRIGERATOR. OTHERWISE THE UNIT WORKS GREAT.
    Scholar:
  • 103 Answers
Check door gaskets, and replace if defective or not sealing.
Posted on Oct 01, 2009
Sropped freezing and refridgerating. lights on, digital thermo reads flatline (no numerals) no sounds at all compressor or otherwise
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Amana ABB1927DE Bottom Freezer...
Tip
Hot door seal, rail, divider strip between refrigerator and freezer.
If the mullion (rail between the fresh food section and the freezer section) on your refrigerator is hotter than normal this tip will help identify and remedy the issue hopefully before it gets to the point of loosing the cooling.
Theory:
Refrigerated surfaces will attract moisture, especially in the warmer more humid areas and times of year. Since the refrigerator and freezer are cold moisture can accumulate near the door from normal use, this moisture can get into the door seals and cause them to not seal properly, mold and otherwise cause a nuisance.
Why Hot:
To keep the moisture from accumulating on this surface the refrigerator manufactures have run part of the hot condenser tubing inside the cabinet close to that rail, under normal running circumstances this rail will be slightly above room temperature and the amount of heat not noticeable. The condenser is the set of coils that are on the back or bottom of the refrigerator and disperse the heat from the unit. If the condenser is very dirty or the fan that keeps the condenser cool is not running then the condenser coils and thus the mullion (rail) gets very hot and overheats. This heat will eventually cause the compressor to work harder and possibly overheat and turn off occasionally to cool itself. This will lead to reduced cooling in the freezer and refrigerator.
Fix: If the coils are under the refrigerator, pull the front grille off of the bottom, check if you feel air coming out, if not then the fan is not running, look for dust and dirt build up on the coils, clean with a brush and vacuum, do not be afraid to get aggressive with the brush. If the fan is not running you will need to go to the back of the refrigerator and unplug the power cord. Remove the back panel off the bottom and you should see the fan. It may have some dust or other debris blocking the fan blade from turning. If so clean that out very good, clean the coils from the back if accessible also. Be sure to put the back panel on as it is there to direct the air flow across the compressor and coils, without that panel the condenser will overheat.
If the fan does not run after cleaning it you will need to replace the fan motor, it is a common part that should be available at most retail appliance part dealers. Just be sure to get your model and serial number before calling.
on May 05, 2010 | Refrigerators
If the compressor is tripped to prevent overheating, how do I reset it once the accumulated dust is vacuumed out?
Your thermal cutoff on the compressor will re-set on it's own when the compressor has cooled down. If it does not, then you will have to replace it.
Sep 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My bottom freezer is not cooling sufficiently. If I keep it closed for 30 hours or more, it does cool, but otherwise it rises to 19 degrees.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 11, 2010 | GE Refrigerators
Thick brown liquid at leg of of refrigerator
the thick brown liquid is decomposing moss, from the condensate inside the unit finding a way out.(think of it as the same stuff you get around a shower tray)clean out the fridge using clorine bleach and dry thoroughly....leave the door open for the clorine to gas off otherwise it will taint the food.when the smell has gone then close door and switch on.(some people use milton fluid,but clorine kills all known germs....)
Jul 16, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
Freezer ice maker stopped working. then entire unit stopped cooling, fan is not working. Light is on inside the unit.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
ghjd
May 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The unit is not cooling the fan inside the freezer is running
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 07, 2010 | KitchenAid KSCS25FKSS Side by Side...
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Viking VCBB363RSS unit is not cooling enough. .The temp will not get cool enough, all the lights still work no problems otherwise. is there something I can do to get the temp correct.
heatman101
67r98uufdkhg
Jun 16, 2009 | Viking VCBB363L Bottom Freezer...
Freezer and fridge not cooling well i clean the condenser fan
heatman101
,.f
Mar 13, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
