Question about Gateway FPD2185W 21 in. LCD Television
All caps replaced and checked to be ok, still blacks out.
Already replaced the all caps on the power board and tested the three remaining caps on teh main board and they are good. Image comes on for a few seconds and the screen goes blank. Any ideas??
  • 624 Answers
SOURCE: Replacing Inverter Board
I did some poking around and only found a few places that sold inverter boards for this monitor. Ebay has one that sells for about $80: http://cgi.ebay.com/Backlight-Inverter-for-Gateway-FPD1930-LCD-Monitor_W0QQitemZ160070918225QQcategoryZ174QQrdZ1QQssPageNameZWINQ3aPOST0Q3aRECOQ3aBINQQcmdZViewItem I wasn't able to find any specific instructions posted, however, taking a typical LCD panel apart and replacing the board shouldn't be too difficult. The only hard part is not getting shocked, which is why this is not a job for the typical user. Anyway to disassemble the typical LCD you remove the pedestal from the back of the LCD then remove the screws around the back of the LCD, remove the back and look for the inverter board. Typically it is covered with a metal shield; again the hard part is knowing how to correctly handle the parts. Considering you can buy a new 17" LCD for $120 to $150 (and has a 1 year warranty) you might want to consider investing in a new monitor instead. If you have any other questions let us know, otherwise please don?t forget to rate this posting.
Posted on Feb 06, 2007
SOURCE: Proview PL716s computer monitor
I opend up the monitor and found that some of the capacitors on the power circuit are bulging. I'm pretty sure that is the problem. I just ordered substitute capacitors and will replace the broken ones with them when they arrive. specs for equivalent capacitor: 470uF 25V 105C
Posted on Apr 08, 2008
SOURCE: monitor goes black 1 second after coming to full screen
Same problem here. Does anybody have an answer?
Posted on Jul 17, 2008
  • 597 Answers
SOURCE: my screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Posted on Jun 02, 2009
  • 12 Answers
SOURCE: same problem 2 seconds on, then turns black
The problem with the monitor is the power inverter board. I took my monitor apart and tested all the power outputs. The ones going to the main board where ok but the ones going to the backlight where different. I changed the three capacitors on the power board that where located between the two heat sinks I think it was the 1000uf and the two 470uf. They looked ok but when i tested them they where off. Next on the opposite side of the board with all the little componites there are a few dry joins that you have to resolder. If you cant find then you can just resolder the whole back board it should only take 30min. If you have no idea what i am talking about i would not sugest taking the monitor apart.
Posted on Jul 28, 2009
Samsung UN40F6300 tv has no backlight. Passes flashlight test. already replaced main power supply board. Is there something I am missing?
Some time the LED back lights can become faulty. If o you have to replace the panel. Because the LED back lights comes along with the panel.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 15, 2016 | Samsung 6300 Series UN40F6300 40" LED...
Blank screen on LCD TV
either the backlight power board or the power board itself isn't powering up the backlight power board
or your backlights are burnt... this is where testing comes in
Dec 30, 2013 | Televison & Video
Picture keeps blacking out. Sound is ok. Removed back and removed power supply board and tested capacitors. All capacitors seemed to be ok. Is if possible that all capacitors are ok and I still need to...
Seems as if you back light strips are malfunctioning or your power supply board is kaput. See:
http://www.partstore.com/Model/Samsung/Samsung/HPT5054.aspx
for an idea of the cost you may be facing
Nov 30, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
I have a Dell 2208WFPt monitor and when power is applied and without pressing the power switch the power light flashes but the display remains blank and dark. I checked the large cap on the power supply...
The replacement board is about $50 (there are three versions), you can try troubleshooting down to components level or replace the board, hopefully is is not bad lamp assemblies (you need to have Inverter test lamp to verify if it is the lamps problem or inverter problem).
http://www.lcdrepair.us/Invpowersupply.html
http://s807.photobucket.com/home/budm/allalbums
What DC voltage do you get feeding the inverter circuits?
Aug 13, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
The tv does not turn on. Power on lamp remains dark. Power cable checked out ok
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Feb 18, 2010 | LG 20LS7DC 20 in. LCD TV
Same problem 2 seconds on, then turns black
Jul 03, 2009 | Gateway HD2200 LCD Monitor
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Power up
I followed instructions posted at
http://vassfamily.net/projects/DMRE85H/dmre85h.html
and I opened the unit.
I unscrewed 3 black screw on back, removed two side covers, then I unscrewed 4 silver screws (2 & 2) on both sides and removed the top cover. Then I unscrewed 4 screws (those four screws that hold the silver hlder on the board - they are down, so you need to use long screwdriver.
Carefully moving & holding HDD in the silver holder (moving it only little bit up from the board to see underneath on the board), and I was able to see 2 blown capacitors (with brown stain on top). They are C1261 & C1260 caps - ELNA 680uF RJF 10V.
I did not attempt to remove silver holder with HDD totally now.
In reverse order, I screwed everything back.
I ordered parts at www.panasonic.com support page for model SC-HT1500, then choosing SA-HT1500 - Main Unit. I found those 2 same capacitors; they cost $1.89 each. Shipping & tax came higher than price of parts. I
I already have soldering iron, and I will try to replace blown capacitors by myself after receiving ordered parts.
I will post my next message after receiving parts - approx. in a week or so.
Dec 03, 2007 | Panasonic SC-HT1500 System
Mitsubishi ws65611
Mitsubishi sets are notorious for leaking caps. These are the black caps labeled "Nichicon" and sometimes "Rubycon". They are easy to spot because the negative leg has what appears to be dark acid leaking down, the board has a circle of discoloring around the cap and sometimes the copper trace on the other side of the PC board is all black and contaminated. If you know what you are doing, you can remove all of these caps, clean up the board and replace with quality caps, and this usually solves the problem.
Jun 27, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
207 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
