Samsung HLP5063W no video only sound/replaced lamp 2 weeks ago
We have a 2005 Samsung HLP5063W. We have replaced the color wheel about 7 mos ago and then two weeks ago replaced the lamp and the TV was working fin. Today the picture went out but we have crystal clear sound. The lamp is working (can see it through the back lit up green when the TV is on), fans are on and we just cleaned out the back (vacuuming). Any ideas? Hoping for a cheap and easy fix. Thx!
  • 1 more comment
  • angie_tickno Oct 02, 2009
    After removing cover again I checked to see if the fans were functioning and everything seems to be good. I called Samsung to see if they could offer some help but that was no real help. I am assuming that if the lamp is lighting up then it is still good. Is that right? Would that rule out the ballast? I don't really have the $$ to take to a repair shop so any additional insight would be appreciated.
  • angie_tickno Oct 04, 2009
    Okay...after leaving the t.v. off for about 5 days I decided to turn it on and the picture came right back. It was working great for an hour and a half and then the picture went away again. I still have audio, just no video. Would you still say that it seems to be the digital board?
  • 8,617 Answers
The digital board is famous for failure in that model. You can get replacement digital boards for that model at www.tvrepairworld.com if its not listed leave them a email as they only list a few of the boards which are available.
Posted on Oct 01, 2009
  • 5,138 Answers
Lamp Ballast Board BP96-00690A or BP47-00027A Found A few on E-Bay, Heres another thing CK DMD Fan if it is not running it will do the same thing it will be right behind DMD big Alium board Call samsung parts for price 1-800-627-4368 or Go to their website.
  • ladywinn
    ladywinn Oct 01, 2009
    CK DMD FAN it will be right behind DMD moduel. other maybe BALLAST BOARD BP96-00690A or BP47-00027A E-Bay has some. Encompass is cheaper on parts then samsung parts 1-800-638-3328 and other# 4 samsung 1-800-627-4368
    Genius:
  • 1,112 Answers
With television on and lamp lit, If you hit your menu key does it show a menu. Also just for checking sake if you are using a cable box disconnect it and using the cable coming from wall connect directly to television and try changing the source input to TV on your remote to see if anything is happens, if not then play a dvd and switch source until u hear the sound of the movie u inserted if no video, then its more then likely that the analog/Digital board assembly has failed. I don't know if you vaccumed it before it went out or after but you might want to check to make sure you did'nt hit any cables wires and loosened a plug on any of the exposed boards. If you do find one of the plugs on a board loose or not plugged snuged in its socket make sure u turn off the power first before reseating it. Also if you are using componet input for video or running video through a audio receiver make sure its set to the correct video output source. and that all cables are snug. Especially the green cable on componet inputs. If this cable is loose or comes out their will be no video.
Please feel free to leave a comment in more info is needed..
Lavell
I hope its just something simple
  • Lavell Turner
    Lavell Turner Oct 03, 2009
    Yes it does rule out the lamp/colorwheel/ballast. Unfortunely you may have a bad video input/output v board assembly, This would emcompass replacing the Digital Board Assemble.
  • Lavell Turner
    Lavell Turner Oct 06, 2009
    Check who manufactured the lamp, if the lamp was made by LTI then i would suggest you replace it, these lamps are of very poor quality and manufacturing. Make sure the bulb says phillips on it, if not replace it with one that does.
I have a Samsung DLP, model hlp5063w. When I turn it on, the picture comes on and a few seconds it kicks off. After a few more seconds, it turns back on. It keeps turning on and off until I unplug it. Any...
2 most common causes of that sympton would be
1. Lamp failure is the most logical culprit BP96-01403a is the lamp number and I recommend only using an OEM replacement
2. Color wheel malfunction. Usually when the wheel fails you will hear a very loud motor spinning sound from within the tv.
If you havent replaced the bulb in a couple years that would be the most logical cause.
Oct 28, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Light bulb not working after colorwheel replaced
Same thing happened to me (By jschmidbauer on Jan 14, 2010). How did you fix it????
Jan 14, 2010 | Samsung - Projection TV replacement lamp...
No Picture But Sound
I have a HNL5065W samsung that i just repair if it was the lamp you would not get sound,When Lamp goes out set will not come on only Flashing front lights, how long does yours play before cutting OFF? There is a couple of capacitors that will go bad on power board,CK to see if any of the capacitors are puffed up on top if so thats your problem.,But remember Ballast starts up LAMP CK the big capacitor on ballast board and small ones ,also Keep in mind it could be Ballast,if set keeps playing with sound and no picture another thing make sure nothing has come unpluged on DMD board, this board also will keep lamp from firing.OK heres another thing IF COLOR WHEEL is not spinning correctly lamp will not fire up, if it spins to slow or too fast most samsungs start out with Bad Color Wheel.I Buy on E-Bay got My lamp for 85.00 Ballast board 55.00 Ballast board at other companys 117.00 plus shipping! Color Wheel was 65.00.
Aug 19, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Have lamp cooling fan noise on Samsung HLP5063W - 50 when I turn on TV and screen is distorted. Noise on TV is gradually getting worse and now does not go away and I essentially have no picture. Do I need...
the problem with your tv is the color wheel
not the fan let me know if you need help to take it apart...
I do repairs for samsung tv and I fixed a lot of them before..
Jul 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
michtech
Feb 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLP5063W Tv
while replacing the color wheel you know you see two cords running from it the blue/white cord and that copper cord. if you replaced both the color wheel and lamp, then it could be that copper cord just switch it around i did that and now my tv works
Jul 15, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Motorized sound and picture quality poor and jumpy
your husband is correct it is most likely your color wheel very common and it will effect the picture. what will happen soon is your tv will not turn on. The cost is two possiablities. color wheel replacement 225,00 part is 80,00 complete light engine in rear cases cost is 650.00 dollars . I hope this helps
thanks doctor video leadingedgeeletronics since 1987
May 04, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Very noisy when turned on, then shuts down, Samsung 61 inch
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
340 people viewed this question
Top Televison & Video Experts
Electro Med Services...
