Question about Mitsubishi WS-55819 55" Rear Projection Television
Can't get it back to tv input - tv connected to 2 direct tv satellites. changed input to dvd mode and now tv mode won't come back up. went to menu to change input and still cannot get tv to come up
    President:
  • 788 Answers
You set may be set to Home Theater mode.
I think it is in the advanced menu.
Set home theater to off. This will fix the input on the television to input one, no matter what you do.
I hope that this helps you.
asnowman
Posted on Oct 01, 2009
LC321ss9 model. How do I get the TV to go to the Satellite mode?
keeppushing that button and it will go back to the starting point . my tv has cable/satelite /antenna/dvd/vcr jsu chose the option that sounds right . can always go back and try other s
Jan 26, 2015 | Sylvania Televison & Video
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
I transfered from watching my sattelite tv to watching a dvd using the tv control. The dvd sound worked ok, but I couldn't get a pictue. Then I tried to watch tv again, but the vidio would not come in,...
Just in case, here's the 108-page user's manual for your TV:
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
Yor "NetCommand" TV remote is a wondrous thing, capable of throwing off anyone.
When the 'Device Selection Menu" is dispayed, and only when the device icon is highlighted,
does the key work, and it also only works when the remote is in "A/V Receiver" mode -
not in "CABLE or DBS" mode, nor "VCR" mode, nor "DVD" mode.
So, (1) set the NetCommand remote to "A/V Receiver" mode
(2) bring up the Device Selection Menu, using the key on the remote
(3) highlight the Satellite receiver input icon (highlighted with a Yellow outline)
(4) press GUIDE on the remote, to swap the analog digital setting.
Also displays ChannelView for Antenna 1 and Antenna 2 - you may have accidentally
set the TV to get its input from the wrong Antenna.
If your TV has lost memory of its DBS source, you may have to re-teach the TV (using the remote)
that the DBS (Digital Broadcast Satellite) input exists, and to which input its connected.
Refer to "Edit NetCommand, Add an A/V Receiver", pages 39-45 of your Owner's Manual.
Jan 31, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Remote doesn't work rca model #F32648,i can't access the input function. The onscreen menu doesn't show it or I cannot find it. Problem is without it I can not use the DVD player.
This isn't a solution but I am unable to acccess the input either. My tv is hooked to a dvd,vcr and direct tv satellite with a dvr. I watched a movie on the dvd and the tv won;t allow me to switch the input back to satellite tv.
Apr 10, 2009 | RCA F32648 32" TV
Can't program coby dvd 224 help
Shana, What are you really trying to do!!!! Do you understand what the jacks on the Coby DVD player are for?? Can you connect the Coby player directly to TV AUX inputs and play a DVD?
Is the satellite 'box' still connected to TV/Monitor using TV Tuner set to chann 3 or 4? Is the TV you
are trying to use have any or none of those YELLOW/RED/WHITE jacks on the back of it that you
have never plugged anything into them. Is the TV always set to Ch3, and is never changed to any
other Ch number??? Do you only change Ch up or down using the satellite "box" tuner? ALL these
questions and more must be answered by you before anyone can help you out. You must know your
own equiptment and its capabilities. The COBY Player will never be found by the satellite dish tuner.
comments or info send to lmistyrel @ aol.com
louie12fix @ fixya
Dec 26, 2008 | Coby DVD-224 DVD Player
Connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Oct 21, 2008 | Televison & Video
Satellite input
Most tv setups require that you change the input source to gain the ability to watch the proper peripheral e.g. if satellite is connected on video one and the dvd is connected to the tv on another input such as video 2.
If the satellite runs into the dvd unit and from there the dvd is connected to tv you may have to power off or on the dvd player to resolve conflict.
Another problem may be the resolution setting if your tv is Hi Def. Set the tv and receiver to the resolution e.g. 1080i.
You can also changed the way the satellite is connected to the tv possibly if you have other inputs.
Check the channel also, if the unit is connected with coax it would more than likely need to be on ch 3 or 4 if you are at the satellite receiver box location. If you are at a stand alone tv off of a dual tuner you may need to search the channels for the right source both air(analog) and cable(digital).
Hope this helps you out. If I can be of more assistance let me know.
Sep 07, 2008 | Proscan PS60690 60" Rear Projection...
How Do I Get a DVD to Work with This TV?
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Feb 16, 2008 | RCA G32665 32" TV
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Mitsubishi WS-55819 55" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
