Question about Refrigerators
The ice cube tray on my LG refrigerator does not return to horizontals after dumping the ice and the water then pours into the freezer compartment spilling out of the tray.
  • 80 Answers
Your ice maker is out of time.
Try manually advancing it if you can or you will need to replace it.
Posted on Oct 01, 2009
Whirlpool ice maker quit.
If it's similar to my Samsung, mine did the same. There is a reset button at the front of the box which contains the ice cube tray. If you press it, the ice tray rotates to dump the cubes, then refills. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Its not producing ice anymore.
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Model 22 Icemaker is not making ice
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
Sep 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water leaking from freezer compartment and ice maker not working properly
I figured it out. When the water filter gets old and plugged up, not enough water flows into the cube trays. You can fix the ice problem by replacing or just removing the filter. (The filter really isn't necessary unless your water comes from a well or some other undesirable source.) The filters cost about $40 from Sears, but you can find them on ebay for under $30 including shipping.
Jan 27, 2009 | Refrigerators
Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
