Question about Samsung SyncMaster 940MW 19" LCD Monitor
Will not turn on. It started when we would press the power button and the power light would blink once. if you pushed it a few times it would eventuly turn on. then it took more trys to turn on and as of now the light does not even blink. is this fixable?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Kirstin_lewi, It is fixable, but you should check with Samsung first! Is it covered by warranty? If not, can they provide you a REFURBISHED unit under a SWAPOUT+$ type program? Is your unit <3yrs old? Some units which exhibit your symptom of failure can be fixed for $30-$70. I would visit youtube and view some video clips (the longer ones) >8min length to see what is involved with doing a repair of a typical LCD display. Search under "LCD REPAIR" or "LCD Disassembly" or something similar. Also query for "bad capacitors", "swollen capacitors", and last but not least "failed inverter circuits" which are the things that provide the 800 to 1000volts needed to light-up your CCFT lamps. I hope that this information was helpful to you. Please rate this response with fixya if you can. I'm louie12fix on fixya or lmistyrel@aol
Bye for now.
Posted on Oct 01, 2009
I need remote control code for Dawin TV
If you do not know the code, you can use the code search function to program the remote control.
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Apr 04, 2016 | Televison & Video
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    Microphone PG58 won't turn on, it has a blinking red light when I push the power button
    Your circuit board could be bad, but i would pull out the circuit board and spray contact cleaner onto the button, let it dry a few minutes and connect the battery and press that button quiet a few times and see if that fixes the problem.
    Dec 06, 2012 | Shure PG58 Professional Microphone
    Have lost instructions to Emerson universal jumbo remote
    Using Code Search:
    Program a Manual Code:
    1. First turn on the device that you want to program such as your TV or DVD player.
    2. Point your remote control at the device.
    3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
    4. Press the "Code Search" button for about 3 seconds until the light stays on.
    5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
    6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
    Retrieving the Code for your Device:
    If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
    1. Press and hold the Code Search for 3 seconds until the light stays on.
    2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
    3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
    4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
    Programming the Sleep Setting:
    1. Press and hold the "SLEEP" button until the light stays on.
    2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
    3. Make sure the remote is pointing at your device.
    4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
    Here is a list of the Emerson Universal Codes:
    http://www.jumboremotecontrol.com/remote_control_code_list.html
    Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
    Mar 08, 2011 | Televison & Video
    I lost my code sheet. how do i get a new one.
    Try to do this:
    Guide to Programming the Remote
    Follow these steps to program a device into your remote control. Thereare two ways to program your remote. If you already know the code foryour device, you can program it into your remote manually. If you donot know the code, you can use the code search function to program theremote control.
    Using Code Search:
    4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button toprogram the DVD player, etc. The light on the remote control willblink and stay on.
    5. Slowly press and release the power buttonrepeatedly until the device turns off. Each time you push the powerbutton the light should blink once.
    5. Enter the code for your device using the number pad. The light willblink each time you push a button. If the code works, the light willturn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work,start from the beginning by holding down code search until the lightstays on and use a new code.
    Ifyou used the code search function to program your device and want toknow the code for future reference, you can retrieve the code from theremote. To do this:
    2.Press the device button for the code you want to retrieve. Press TV toget the TV code, etc. The light will blink once and stay on.
    2. Use the number pad to enter 2 digits for how many minutes to use forthe timer (01 to 99 minutes). The light will turn off and start timing.
    SOURCE
    Sep 29, 2010 | Innovage Jumbo Remote Control
    Error 5100 when I try to print anything . bought it few hours ago can any body help?
    hi try this 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal..
    Jun 09, 2009 | Canon PIXMA iP1300 Printer
    Insignia TV code for RCA Universial Remote Control (RCR450)
    If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
    Good luck
    Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
    S9000 canon printer ink tank full
    Hi
    Try this see if work for you.
    may work
    Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
    1. Turn off printer
    Nov 02, 2008 | Canon i950 InkJet Photo Printer
    Error number 1700 canon s9000 printer
    knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
    Waste Ink Tank Reset
    1: Power off printer
    2: Hold Resume button then press and hold POWER, the beeper will sound once.
    3: Hold POWER and release RESUME
    4: Press RESUME twice, then release all buttons
    5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
    6: Press Power to set data
    1. Turn off printer
    1. power off Printer
    2. Push and hold resume button and push power button
    3. Hold Power button and release Resume button
    4. Push Resume button twice ( 2x ), and now release resume button and power button
    5. Green light will blinking and stop.
    6. When green light on, push resume button 4 x
    7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
    Aug 20, 2008 | Office Equipment & Supplies
    Samsung SyncMaster 940MW 19" LCD Monitor Logo
    218 people viewed this question
    Top Samsung Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
