Question about Porter Cable 2 - 1/2" 15 - Gauge Angle Nailer Kit
My gun is leaking air ... a have 2 finish nailers and are leaking air , please can u tell me where can send those to fix?? i'm in north south carolina my sip code is 29536
  • 339 Answers
The closest loction to you is in Charlotte:
DELTA | PORTER-CABLE/DEWALT FACTORY SERVICE #042
3557-B WILKINSON BOULEVARD
CHARLOTTE, NC 28208
US
704-392-0245
Posted on Oct 01, 2009
What is the problem? will not load the plunger to drive a nail
It sounds like the nail gun might need a lower end seal/repair kit.
Aug 09, 2014 | Porter Cable-Cable FN250C 1-inch...
Hi I have a problem the fan of my gun keeps goin on and on when I put the batterie I don't know what is wrong! Does anybody knows??? Please comment!!
Try taking it apart and cleaning it. If that doesn't work, it doesn't sound like a DIY fix kind of problem...I'd send it in to a service center. Here's an article with videos about how to clean your Paslode finish nailer. If cleaning doesn't work, these guys are also a Paslode repair center.
Mar 28, 2013 | RTO PasLode 900420 Impulse Framing Nailer
I have a Porter Cable finish nailer model FN250B. I have air escaping the exhaust deflector cap all the time and the trigger won't repond. I'm not sure if it's jammed or seals are blow. Can you...
The link below will show a parts list for your gun. Leaks from top are usually caused by debris in the gun. Remove the head and examine parts for cracks or worn orings. Replace parts as needed. If all the parts in the head look ok, clean and apply silicone paste lube to orings and other parts that make contact with orings (silicone paste is sold at Lowes in the plumbing department and at swimming pool supplies stores). Usually, cleaning and lubing with silicone will stop leak. Good luck with your repair.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/portercable/FN250B
May 28, 2011 | Porter Cable Cable Factory Reconditioned...
Finish Pro 32 is Leaking air out of the exhaust cap
You have worn or broked o-rings/seals inside the gun. The Finish Pro 32 is one of Senco's older guns and they no longer offer a repair kit for this gun. You have to go to a site like www.senco.com or www.ereplacementparts.com, find a breakdown of your gun and order each part you need. If you are going to rebuild the gun order all the o-rings/seals (Senco parts that start with LB) and any other parts that may be damaged like the piston stop, springs, etc. Lubricate the o-rings with light grease as you put them in and make sure to oil the gun regularly when you are using it to make your work last.
Jan 27, 2011 | Senco FINISHPRO32 ProSeries 16 Gauge...
T250S-F16 16 Gauge Straight Finish Air Nailer i have an air leak out of the front of the gun where the driver comes out and makes contact with the nail head (the hole tri-shapped hole) It only leaks after...
Air leaks from the bottom of nailers are due to leaking oring /s that seal cylinder to body of gun and/or leaking thru seal at top of cylinder where headvalve seats. Remove head and examine sealing surfaces of headvalve and top of cylinder. Must be smooth, then pull out cylinder and check oring/s that contact body of gun. Remove any fine scratches on inner body with fine paper (400 grit). Lube with silicone paste. Good Luck!
Sep 26, 2009 | NRS Paslode T250-f16,s200-s16 Nailer &...
Stanley finsish nailer and air is leaking through the trigger as.
If the air is coming out the trigger it must be replaced. Depending on the model of gun you will have to replace the trigger assembly or various o-Rings. Find a Bostitch dealer in your area and they will supply the parts you require.
Jul 14, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Describe your Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit ProblemCompressor builds to 80PSI and will not shut off or build...
sounds like an air leak of some sort. when you get it up to as high as it will go, turn it off and listen for an air leak. Let me know where it is leaking and i will tell you what to fix
Jul 13, 2009 | Stanley Factory Reconditioned Bostitch...
We have a Bostitch nailer that leak out of the end
there are o rings inside the nail gun, remove the allen head screws and get replacements.
Apr 10, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Gun failure
bertobryan45
Have you been lubricating it regularly with nail gun oil. We use framing nailers every day at the commercial tree farm I work at and one of the operating instruction is to put 6 to 8 drops of oil in the air hose connection on the nailer before every use. I suspect the O ring on the piston is worn out/
Hope this helps Good luck Loringh PS Please leave a rating if appropriate Thks
Nov 15, 2008 | Dewalt D51256K 16 gauge finish nailer kit
Porter Cable 2 - 1/2" 15 - Gauge Angle Nailer Kit Logo
280 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
