Question about Pyramid 4 X 10 SPEAKERS Car Speaker
New car speakers cut out when I turn up the volume.
I recently replaced all my factory speakers with new ones. The problem I'm having now is that when I go to turn up the volume, the driver back speaker cuts out making the whole system go low. Can someone help.
  • Anonymous Mar 23, 2014
    when I turn volume up the speakers cut in and out
  • 56 Answers
You just have to check all of the speaker wiring.It's a wire touching somewhere and it will do that till you fix it. What it is is just where the negative wire which is the ground for your spreakers it's touching the positive wire which is know as a power wire.When this happends it lowers the frequency of the volume which will cause the speakers to cut out and volume level to drop.
Posted on Dec 21, 2007
I purchased pioneer speakers and am attempting to replace my stock speakers. Problem is there is already a plug and outlet on the factory speakers, which there is not on the new speakers. is this called ?...
yes they are called speaker harness adapters. You can just cut the factory ones off if you know the polarity (positive/negative) of the speaker wiring.
An easy way to find out is take a 9v or AA battery and two pieces of wire. Strip the wire and attatch one piece to the positive and another to the negative of your test battery, I use red wire for (+) and black for (-). Then take the other ends and touch the factory speaker connector (where it plugs onto the speaker). If it moves out or UP then you have the polarity correct and the wire that your red tester went to is the positive of the new speaker and the black test lead wire touched the negative. If the speaker moves in or DOWN then you simply have it reversed.
All pioneer speakers come with a set of wires so you can cut the factory connector off and put the new one on.
Sep 24, 2011 | Jeep Car Audio & Video
Everytime i try to play my system at full volume it cuts out then keeps playing and carries on doing this to i turn it to a certain volume
First of all find out the recommended speaker impedance for the receiver. Then find out the impedance of the speakers you are using along with it.
Simple rule is the speaker impedance can be higher but not lower than the recommended value. If it is so the receiver will run hot and if you turn up the volume higher it will run even hotter and then the protection circuit will cut off the Amplifier output to prevent burn out of components. Even if you have one defective speaker this cut off can happen. To confirm defective speaker -- disconnect one speaker at a time and turn on the amplifier and play it at cut off volumes.If by disconnecting one particular speaker the Amplifier does not cut off -- THAT SPEAKER HAS A SHORTED COIL and needs replacement.
Apr 03, 2011 | Philips Audio Players & Recorders
It could be your wiring as well. Sometimes, when speaker wire gets cut and grounded, like your factory wiring to your door speakers or you tap into facrotry speaker wires to add more, the load on your deck increases. When the volume gets to a certain level, it will cut off because of the heat produced to maintain the load.
Feb 23, 2010 | Pioneer DEH-P4000UB CD Player
My car speakers cut out when i turn my volume to loud what could the problem be i have stock speakers in a 02 chevy truck and a brand new jvc radio
Hello soccer_fr704,
Sounds like the JVC is overdriving the speakers. Most OEM speakers are just not designed to handle more than 12-15 watts RMS and the JVC is rated at 22 watts.
About the only solutions are to keep the volume really low or replace the speakers with ones that can handle the power from an aftermarket receiver. New speakers will make that JVC sound better, too.
Hope this helps.
Jul 09, 2009 | JVC Car Audio & Video
More than likely with a 2003, the speakers that cut out are in the door or doors. Do they cut out of both speakers?
If they cut out of one, then you may have an intermittent speaker ( the wire to the cone becomes partially connected)
If both speakers turn off at the same time and you hear NOTHING on all speakers, then you more than likely have an intermittent connection on the radio itself and probably replacement is probably cheaper than fixing the radio.
One more thing
Factory radios sometimes have an amplifier in them. Sounds funny but they call the Radio in the dash the Head Unit and the amplifier is buried in the dash. You could have a bad amplifier or a loose power connection to it, but that is very unlikely.
Hope this helps.
Mar 02, 2009 | 2003 Chevrolet Silverado 1500
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
Car Audio Cutting Out
stereo is detecting a short , or low load on speaker wire and or speakers .Go behind car stereo , disconnect all speakers and apply a known good speaker to one of four wires and see if volume works normally ..If it works use same speaker on all outputs one by one ..If all are okay then you should figure out what speaker and or wires are causing issue..Also make sure your ground is okay
Dec 01, 2007 | Pyramid 4 X 10 SPEAKERS Car Speaker
Car Audio & Video Logo
875 people viewed this question
Top Pyramid Car Audio & Video Experts
Greg Cann
Greg Cann
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
