Question about Linksys WRT160N Wireless Router
Can't get laptop to connect on secure connection
  • 20 Answers
Hello please make sure you have configured the laptop wireless adapter with the security code required by the secure connection. If you have any questions let me know
Ryan
www.cobaltsys.net
Posted on Oct 01, 2009
My wifi detect an available on secured connection but when i connect it they tell me can not connect
A secured WiFi connection has been setup to prevent unauthorized access. To connect to a secured WiFi connection you need to get permission from the person that has this secured WiFi connection and get them to give you the encryption key (password).
Dec 26, 2012 | Acer TravelMate 5720-6635 Notebook
Trying to connect wirelessly to 2 wire. I get limited access icon
Hi groveland1,
I see that you are having issue with your Internet Connection, Limited or no connectivity is a possible issue with your network key / security key on the router and your laptop.
1. Try and check the network key in your router.
2. Check your network settings in the Laptop and see if the security settings in your Laptop is the same as the security/network key in your Router.
3. If possible recreate your wireless connection in windows for a fresh connection from your Laptop to your Router.
4. Change your Network Key in the Router and in your Laptop see if it will connect in-case you may have forgotten you old Network Key.
Hope this helps.
Apr 04, 2011 | 2wire (1000-400108-001) Router
I need the security key to my existing wireless netgear router.
The Security Key is normally used for Wireless routers to protect your connection from any unauthorized use. As you have said that you do not have the Security key for your router with you, the best way to connect your ACER laptop to the Netgear router is by asking your Wireless service provider to reset the security key & freshly reentering the same on both of your HP & ACER laptops.
Feb 06, 2010 | NetGear RP614 Router
Why cant i access sites on my laptop it comes up with security certificate also i cant acess my email account on google its all new to me never used a laptop before and im not sure if it comes with any...
If you cannot access any website on your laptop check if you have interent connection first. Check if your laptop is set to connect using a proxy server check the Local area connection. If your using wireless check if you wireless setting is correct. Run ping test to determine your internet connection For windows click START > RUN > type ping yahoo.com if the message is reply from then your connected check you laptop security settings. If unable to connect or request timed out contact your internet provider
Nov 20, 2009 | Google Gmail
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Belkin Wireless G Plus MIMO (F5D9230-4)
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wirless Network keeps failing
It is possible that you need to further fine tune your WEP configuration. To verify if it's the security lock, try running the laptop and the router without the WEP security (disabled) and determine if you still get the "Limited connection or no connectivity".
If yes, you have just eliminated that area and could consider other possibilities, otherwise you then have to concentrate on the WEP security.
Hope this be of initial help/idea. Pls post back on any developments (or lack thereof) or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Wireless connection
You will need to speak to the person in charge of the security enabled network, and obtain the type of wireless security (WEP or WPA) and the password.
You should also determine what security types are supported by your own laptop's wireless connection. If it is an older one, it may only support WEP, and you will be unable to connect to any WPA protected networks.
Dec 07, 2007 | Compaq NC4000 (DG987AABA) PC Notebook
D-Link Router
first of all are you talking about a secure wireless connection. if you aren't, then what it means is using an encryption key to secure your wireless connection. any computer connecting to your router can connect wirelessly and use your connection to do whatever they want unless you secure it. let me know a little more details and i will help you get it all set right.
Sep 19, 2007 | Computers & Internet
Linksys WRT160N Wireless Router  Logo
71 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
