Question about Alpine Air Eagle 2500 Air Purifier
What order to the 3 wires go on the on/off swith. ther is a purple, black and orange wire
  • mrfixit78741 May 11, 2010
    give us a descprition of your system /indoor or out door
Found my note with the info i needed. neveremind and thanks for your help.
Posted on Oct 01, 2009
Where does (light green) ground wire attach to, came loose mhen I opened top thank you
We will need to know the make and modek in order to help you.
Apr 25, 2015 | Air Purifiers
Troubleshooting
This could be due to a factory wiring error and you may have to make some adjustments to allow installation of the plate.
Nov 21, 2013 | Alpine Air XL-15 Air Purifier
I cant get the 3rd plate to go in to place purple wires r keeping it from going all the way
Third plate? Not on an XL-15. There should only be two slots. Send pic so I can help further.
Nov 20, 2013 | Alpine Air XL-15 Air Purifier
Hi i have a Ecoquest Breeze AT Living Air
that ligth its uv lamp you can replace it your self get parts from ecoquest for the rigth model
Apr 02, 2010 | Ecoquest Breeze AT Living Air Purifier
The guide wire(s) inside my ionic breeze bathroom air freshener (model S1717) broke. How can I replace these wires?
either cut and strip wires and wirenut them back together or order another harness i suggest the first option
Feb 23, 2010 | Sharper Image Ionic Breeze Air Freshener...
I replaced a Lennox DSL-450LX heat pump thermostat with a Honeywell RTH3100C. Everything works except the gas does not ignite when set to emergency heat. The Lennox was wired as follows: W = white wire Y1...
Hi, If indeed you do have a heat pump, there wouldn't be any gas involved as a heat pump runs on freon with a reversing valve and heat strips for aux and emerg. heat. For gas electric operation thermostat terminals are rc to rh with factory jumper. Red wire to either.W to W for Heat, Y to Y for cooling G to G for Fan. If you have a blue, you wont need it unless this is a commercial stat useing a common for the Led lights on the stat. The unit will get its 24volts through R terminal in combination with y,w,and,g. Cant be a heat-pump if you have a gas furnace.Wrong t-stat. You need a gas /elect stat. And on a 24volt programmable t-stat, the batterys are used for the program only.If the batterys die, than you will loose the program on most residential stats. On commercial stats with the common in play, when batters die the stat defaults back to the factory settings.If you had a Lennox heat-pump stat on a gas/elect unit, you need to change it. Someone was using what they had on hand. Let me know if this has helped you.I will be here if you need me. Sincerely,
Shastalaker7
Nov 17, 2009 | Air Purifiers
My filters turn black after about a week
I am also experiencing this problem, as well as 2 other people that I found on google, so I am inclined to think tha 3M has changed something in their manufacturing process, I think it very odd that this problem is manifesting itself at this time in different locations.
I have been using this product for sometime, and the problem of filters turning very dark did not exist when I started using this product
Jul 02, 2009 | 3M Filtrete Ultra Allergen Air Filter...
Thin wire broken in front
Describe this wire, is it a small silver shiny wire? It is most likely the ni-chrome wire or high tension wire that zaps the particles, I would think thay would have that part available have you called them?
wbwill@sbcglobal.net, if it is obsolete you can mail it to me and I will take a look
Nov 12, 2008 | Sharper Image Professional Plus Ionic...
DOESN'T RUN ANYMORE
Check the capacitors. There are two to look for, one on the motor, the other on the PC controller board.
STEP ONE: Unplug the unit and support it on a table.
STEP TWO: remove the controller board from the exhaust side of the unit by unscrewing the screws holding the cover to the unit. Unplug the motor wire harness by pressing down on the white retaining clip. They go only one way, but it doesn’t hurt to note which is which.
STEP THREE: Unbolt the ground wire from the face plate and the whole board should come out. Unscrew the four screws holding the PC board. Look for a little foam pad that will drop out. Remember where to replace it. Screws and capacitor may have blue locktite on them.
STEP FOUR: Find the capacitor. It’s the part that looks like a tootsie roll, black with two wires coming out one side. It’s between the CPU chip and the big red square block. If it looks bloated, burnt or melted, you found the problem. Replace it with a 1000 microfarad (1000 uf/ 10 volt) ten volt capacitor with a radial lead. About $5 for the part at most electronic parts stores. Careful desoldering the old capacitor to avoid damaging the PC board. WATCH THE POLARITY. There is a negative and positive side. The negative side has a chevron (<) mark and is marked on the PC board. On mine the negative side was nearest the black micro chip and the positive side was towards the red JEFU MPE part. Use a little bolt-tite on the screws of the PC board and some on the capacitor on the PC board to limit vibration. Reinstall the board, plug it in and give it a whirl.
If no joy, STEP FIVE: Find the motor start capacitor. It is bolted near the motor, black about 1x 2 x 4 and has two red wires coming out of it. Take a battery operated resistance meter on a setting of R x 100 or higher. Charge the capacitor by connection one lead of the tester to one red wire and the other lead to the second red wire. You may have to strip the wire to make contact. Next reverse the leads and you should see the needle jump. Do it a third time incase the first try was discharging. If no needle jumping, replace capacitor. Couldn’t find this locally. May have to by directly from JET Tools. L
Recommend you hard crimp wire splices if cutting off the motor capacitor. .  You can check the windings on the motor too. Check for continuity between the white-yellow-blue-black wires of the motor harness. Any combination should work. If not, motor shot, time for some bigger bucks nrepair.
Hope this helps.
Jan 06, 2008 | Jet AFS-1000B Air Purifier
Red light when swith on power button ?
cell is dirty, or you have a broken wire in the cell.
Dec 22, 2007 | Oreck XL® Air Purifier
Air Purifiers Logo
299 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Jeff Osterhout
Jeff Osterhout
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
