Question about Philips 50P8341 50" Rear Projection Television
I have a phillips model 60PP9202 that will not power on at all. Is this unit equipped with any fuses?
  • Philips Master
  • 1,210 Answers
The fuses are probably good as you can check...The big solution is you have a weak or bad small signal board. About the size of a deck of cards, located in the back on the left hand side, you will see this when you open the back cover. Try this, leave your tv unplugged for a few days or even a week or two. Then plug it in and see if it will come on....if so the answer has been said. Be patient my friend.
Posted on Oct 01, 2009
  • matt martin
    matt martin Oct 02, 2009
    Your part# may be 310432816305. You may ask a tech. Or call Andrews Electronics..Give them your model# and Chassis# to verify exact replacement. Phone#1 800 274 4666 or call PTS Electronics at 1 800 844 7871. Good Luck!
No power phillips hdtv projection
Follow cord inside and as seen from rear to the right where cord enters there are at least one and maybe two fuses.
See if the fuses are good or bad.
Dec 13, 2012 | Philips 60PP9202 60" Rear Projection...
I have a Phillips rear projection tv model number 60PP9202/17F.....it 60
What is the problem of your
Phillips rear projection tv model number 60PP9202/17F?
Jan 10, 2012 | Philips 60PP9202 60" Rear Projection...
Turned off by itself and never came back what part will I replace
If the TV is completly non-responsive (ie not even a flicker of light on the power button) then one of the first things to check on this is the fuses - easiest being the right corner next to where the power cord plugs in (have to take off the back panel)
May 30, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP9202/17 F No picture No sound
Does the power light still work when you have the above problem? If so check the site www.tvrepairkits.com. They should have a repair kit for this model.
Sep 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Problem with phillips 60 projection tv
Possible cause could be a defective HVG (5904). Replace part with part number listed in this service manual.
Possible cause could be a defective Convergence
Amps (7044 and 7045) on Small Signal Module.
Replace part with part number listed in service manual.
Jul 29, 2008 | Philips 60PP9202 60" Rear Projection...
Philips HDTV wont turn on
If your model number is 60PP9202 you dont have a bulb, you have three CRT picture tubes instead, and if the power light doesnt come on check the fuse on the power board. Remove the rear cover after unplugging the cord and look at the small board on the irght where the power cord attaches you will see a fuse its most likely blown.
Jun 27, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
