Question about Bissell 8910 ProHeat Clear View Upright Vacuum
I need direction how to use my Bissell powell cleaner?I can't remember hoe to suction up the cleaning solutions?
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vgf
Posted on Sep 30, 2010
Bissell Big Green Carpet Cleaner has poor suction why?
Hello, this is Ava with Think Crucial.
Most of the time the reason why vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this. You may need to refer to your User's Manual for instructions and guide.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 28, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 spraying solution but not water
Hey, sorry to hear the spray isn't working on your machine.
Here's a quick link to the complete troubleshooting steps for no spray for your machine.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Feb 13, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
It won't dispense cleaning solution
Hey, sorry you're not getting any spray. Here's a quick link to troubleshooting steps to assist you.
Jan 21, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction on my Bissell Ready clean carpet cleaner
After cleaning is finished, Rinse out any left over soap from solution tank.
Refill with two cups of cool clean water and add two tablespoons of apple cider vinegar Braggs works great run trigger until all solution is spent.
No more clogged jets. Hope this helps..
Jun 28, 2012 | Vacuums
Bissell ProHeat 2X(9200) hose to cleaner solution no suction
There are a couple areas to check:
1. The black gasket where clearview water collecting unit and the base's front meet. Ensure gasket is in good condition.
2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
Jun 30, 2009 | Bissell 9200 Upright Vacuum
My bissell 3595-2 vacuum cleaner started turning off the power automatically. Now I can not get it to turn on. This vacuum cleaner is still in real good condition, as I have hardly used it. Please...
Most Bissell vacuums have Thermal Motor Protection which is a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting. When the motor cools for approximately 30 minutes, the thermal protector automatically resets and cleaning may continue. If the cleaner will not turn on or the thermal protector continues to activate, your cleaner may need servicing.note: the thermal protector controls the main vacuum motor only, not the brush motor. If the thermal protector activates, the brush will continue to operate normally; however, there will be no suction.
Ava B.
Sep 03, 2008 | Bissell Vacuums
I have a Bissell 3760-2 and while vacuuming it just shut off. The vacuum was plugged in and was on. Thought it might have quit because of the filters, so I cleaned them out and still does not work. Please...
Most Bissell vacuums have Thermal Motor Protection which is a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting. When the motor cools for approximately 30 minutes, the thermal protector automatically resets and cleaning may continue. If the cleaner will not turn on or the thermal protector continues to activate, your cleaner may need servicing.note: The thermal protector controls the main vacuum motor only, not the brush motor. If the thermal protector activates, the brush will continue to operate normally; however, there will be no suction.
Ava B.
Apr 01, 2008 | Bissell Vacuums
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
