Color of images turned bluish green - Televison & Video
    Scholar:
  • 158 Answers
Picture Tube is very weak and you could have a tv technician put a booster on it or give it a charge with his charger machine. I must warn you that it might repair the picture tube or burn it out.
Posted on Oct 01, 2009
Why does my Westinghouse 32" flatscreenTV shows fuzzy psychedelic colors
Have you tried resetting the TV's settings to the factory default?
You should be able to do that within the settings menu on the TV.
May 01, 2014 | Westinghouse LTV32W6HD 32 in. LCD...
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
Color is off....keeps turning bluish. Greens appear yellow
Funny colors is most often caused by a loose cable.
make sure BOTH ends of the cable are secured by tightening down on the thumb screws
Feb 01, 2011 | MegaVision MV220 Monitor
All DVD movies are bluish. How to adjust color to be natural?
if you are using component cables, check the cables for correct color configuration to your TV and from DVD Player.Example red to red green to green and blue to blue, if they check out,the possible problem might be a defective cable...
Dec 29, 2009 | Sony Audio Players & Recorders
Bluish color right coener
I'm afraid, it is problem of optics unit block (light engine), there are 3 LCDs red-green-blue for color picture formation and blue LCD sounds bad, please call local TV tech for fix.
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Emachine monitor lose color.
HI Bernard,
This sounds to me like the video lead is loose. Could you please try the video lead each end and tighten the locking screws if possible.
Regards
Nick
Oct 29, 2008 | E-Machines eMachines Monitor E15T4
Screen Spots
move your streo speakers or any thing w/magnet
Jul 06, 2008 | RCA F32650 32" TV
Orange projection lamp on. Picture is a bluish green, no true white.
If you are in warranty contact Lg electronics since they own Zenith. I was having similar difficulties and they are sending me a replacement tv even though I am out of warranty by 3 years.
Jun 09, 2008 | Zenith D52WLCD 52" Rear Projection...
Monitor color problem
there should be color adjustments in your menu.
also i don't think its the cable if its blue, cuz, if you was miss just blue it would not be blue. and if you had red and green it would not be blue. some video cards have settings to adjust the color in the driver settings or display properties. good luck.
Apr 10, 2008 | Gateway FPD1975W 19" LCD Monitor
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
