Question about Dishwashers
Bosch dishwasher Low circulation water pump pressure
    Master:
    Sergeant:
  • 482 Answers
Pump is going out.
Posted on Dec 20, 2007
I dont ave hot water in my dish washer
These have a instant water heater or circulation pump with in built heater. It could be the relay on the control module burnt out. Either that or possible water pressure / level issue's or pressure switch issue.
Apr 07, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
SG13002GB/07 bosch dishwasher: Water isn't getting
1. Water inlet valve is faulty = replace 2. Main motor (circulation pump) faulty = replace
Jun 23, 2017 | Dishwashers
What does it mean when F 14 is displayed in the window?
F14 - "level/pressure switch failure." The level switch monitors the dishwasher's water pressure, as it circulates, which is especially critical, during the heating cycle (main wash). Level switch failure can commonly happen from poor circulation, or from the defective level switch, itself. The most common reason for poor circulation is low water fill level. In other words, during the water intake cycle, insufficient water came into the dishwasher. Observe if enough water did come into the dishwasher, Check the water level, by using the filter's handle (located on the floor, of the inside of the dishwasher) as a reference point. At the end of the water fill stage, the water level should be just underneath the filter's handle. If the water level is more than half an inch, below the filter's handle... then that could be a problem. The sympton would be a noisy, sluggish, whooshing sound of water, during circulation - It wouldn't be the same old quiet Miele dishwasher you knew.
If you have the low water fill problem, then look at the dishwasher's water intake hose. Miele call this their Waterproof System hose (WPS). It's a water hose with an integrated electric valve. First, shut your water valve that connects to this WPS; disconnect the WPS from your valve; look inside the end of the WPS. With a needle nose plier, remove the rubber seal, filter and the water restrictor; clean them of any possible debris; put all the parts back into the WPS, securely; reconnect the hose; open your water valve; and test the dishwasher. If the problem persists, then the WPS will need to be replaced (WPS~$170).
Other causes for F14, can be weak circulation from foreign item(s) (plastic wrapping, broken glass, etc,...) lodged inside circulation pump impeller, or no circulation, at all (circulation pump stuck). Of couse, the defective level switch, itself, can cause the F14, too. The least common causes for the F14 can be broken wires to and from, level switch and electronic unit, and a defective electronic unit.
Oct 18, 2010 | Miele Premier-Plus Built-in Dishwasher
F14 is presenting after completing 75% of cycle, then the machine stops, this happens on all cycles
Hi dear.Please follow this if you can do it,other wise call service department.I hope that solves your problem.Thanks. F14
Water intake fault: Heater pressure switch
Cause:
Heater pressure switch B1/13 defective.
Remedy:
1. Check the heater pressure switch.
2. Check the connection plug and wiring harness.
3. Replace the heater pressure switch, if necessary.
Cause:
Circulation pump inoperative. Circulation pressure too low (no pressure at
heater pressure switch). Pump may be blocked by foreign objects.
Remedy:
1. Check the circulation pump for foreign objects.
2. Check the circulation pump capacitor.
Aug 18, 2010 | Miele Premier-Plus Built-in Dishwasher
Dishwasher does not circulate water
I had a similar issue and it was the Motor Circulation Pump. Part #239144 @ Marcone Appliance Parts Center (860) 548-0080
Feb 01, 2009 | Bosch SHU5315UC Dishwasher
Bosch shu3036 upper arm with low pressure
check water level should just appear above filter failing that a common fault on these is the impellor wings have worn you need to strip wash motor down to get impellor cover off
Jan 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43C02UC/47
How to loose up the circulation pump
Oct 22, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHX46A dishwasher
I have a Bosch SHX46B05UC/14 and it stopped functioning right. It filled, it ran, it drained, it sounded okay, but I finally determined there wasn't enough circulation pump pressure to swing the spray arms. Turns out the problem was a pump pressure adjustment screw, accessible under the kick plate, had backed off--now if I can only figure out how to set it properly, low enough to clean the glassware, high enough not to break the pots and pans--or is it the other way around. I also found some beans in the drain sump (easy to remove cover plate from inside with a torx driver, large object trap not locked down properly and a riser for the upper spray arms not press fit sufficiently into pump outlet (I wonder if I blew the line while setting pump pressure. I AM looking for guidance on how to properly set the pump pressure, for the moment, I simply turned it into its spring loaded range and cranked it down a few turns.
Oct 04, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Dishwasher
the spray arms are rotated by water coming out of angled jets, this water being forced round by the main circulating pump. suspect it may a fault with this pump
Mar 23, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
83 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
