Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
F1 llight on, oven locked, stove beeps every few seconds
Tried to do self cleaning - winds up with F1 in led display, and stove beeps every few seconds - oven door is locked.
  • 80 Answers
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
John
Posted on Oct 01, 2009
Tip
Please help. We are a cleaning crew that went to a client's home to do a reno...
If you are having oven problems with your GE XL44 oven then you need to do a bit of oven troubleshooting. The first part of that problem is to know what the oven fault codes are trying to tell you.
The codes F0, F1, and F7 could either be a problem with the control or the keypad.
-to see what the problem is cause by, push clear/off on the keypad. Then disconnect the ribbon connector from the control. Wait at least 35 seconds to see if the code comes back. If the code comes back then the control is the problem. If the code does not come back, then replace the key panel.
F2 – This means there has been a problem with the temperature of your oven. It could be a cooling fan or air flow problem. Also could be that the oven got too hot in either a baking mode or a cleaning mode.
-check to make sure the contactor contacts are not welded together. If this happens the oven will always be putting out heat, even if turn off. The thermal switch may also have burnt out. If this switch is open then the fan may be bad, causing the thermal switch to activate. The thermistor that senses oven temperature may also bed bad or have a poor connection somewhere.
F3 and F4 - These are oven temperature sensor codes.
- check the sensor by removing power to the range and then removing the sensor. Check that the sensor reads approximately 1100 Ohms at 72 degrees F. Then check the oven sensor lead to make sure that it is not shorted out. Then check the terminals to make sure that you are getting good contact. If everything checks out okay, then replace the control.
F5 – This is a relay safety circuit failure code
-check the lock circuit for problems. Then check the thermistor for high resistance. Press clear/off on the key pad and reprogram the control. If the code is still there then replace the control.
The F5 code can also result from a short loss of power. If you had a power flicker then reset the control.
FC – This shows a problem with the door lock circuit. Check all the wires and the switches. Check the operation of all the switches.
FD – This is a problem with the meat probe. Check the probe wiring and the receptacle where the probe plugs in at. Resistance on the probe should be 30 to 50K ohms at 72 degrees F.
FF – This is a problem with the door motor safety circuit. To fix this the control will need to be replaced.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Jul 01, 2010 | Ovens
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have Model #JER8750AAB Serial#16776012WK When uising the self cleaning feature, oven stopped and F1 displayed on stove ??
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Dec 19, 2010 | Jenn-Air Microwave Ovens
It displays F1 . Is this a fuse problem and where is the F1 fuse
HELLO THERE
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Feb 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
The door on my frigidaire stove model # FEF389WJCC locked and we are unable to get it open. We werent self cleaning the oven so I'm not sure what happened. Any suggestions how to fix it? We did try...
Hello kmgtsg,
Welcome
You said, The door on my frigidaire stove model # FEF389WJCC locked and we are unable to get it open. We weren't self cleaning the oven so I'm not sure what happened. Any suggestions how to fix it? We did try turning the breaker off and that didn't help.
Did you leave the breaker off for 5 minutes or just flicked it off and on?
It may be a faulty door Latch
The door latch consist of a micro switch and solenoid. Once the door is closed and the latch handle.
But first try to deactivate the door lock
Oven Lockout
To activate the Oven Lockout feature:
1. Press and hold for 3 seconds
2. After 3 seconds a beep will sound, LOC will appear & "DOOR
LOCKED" will flash in the display. Once the oven door is locked
the "DOOR LOCKED" indicator will stop flashing.
To reactivate normal oven operation:
1. Press and hold for 3 seconds. A beep will sound. LOC will
clear. The "DOOR LOCKED" will continue to flash until the oven
door has completely unlocked
2. The oven is again fully operational.
Let me know if these procedures work for you!!
Huuum,
Please remember to leave a rating!
Oct 14, 2008 | Frigidaire Kitchen Ranges
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Elite Electric Range, Display stuck on LOC
I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
Feb 03, 2008 | Kitchen Ranges
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
716 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
