Question about Mitsubishi VS-60719 60" Rear Projection Television
Convergence-Advance Features Menu
My TV does not operate properly although I followed the advanced features menu: Convergence. What is wrong?
  • 143 Answers
These sets are common for solder connections in the convergence ics solder them also look for blown fusses and look at the coils and resistors in front of the ics
Posted on Dec 20, 2007
Why do the headlights. Come on when any door is opened on my 2008 trailblazer
The Headlamps On at Exit and Perimeter Lighting modes can be adjusted using the steering wheel controls to select the wanted function as displayed in the driver information center. The Headlamps On at Exit selection will allow the driver to customize the period of time that the headlamps remain illuminated upon exiting the vehicle. This period can be adjusted from 0 seconds to 180 seconds. The Perimeter Lighting feature allows the driver to select if they want the headlamps and backup lamps to illuminate when the door UNLOCK button on the key fob is activated. This feature can be turned ON or OFF by using the driver information center steering wheel control buttons.
programming Features with the Driver Information Center (DIC)
To enter programming with the driver information center (DIC), perform the following actions:
Turn the ignition to RUN.
Place the vehicle in PARK.
Press the Personalization button on the steering wheel to enter personalization programming.
Automatic Door Locks
Continue with the following steps in order to personalize the automatic door locks:
Press the Select button in order to enter the menu. The first choice seen is the current setting.
Press the Select button in order to scroll through the following options:
• LOCK DOORS: IN GEAR
• LOCK DOORS: WITH SPEED
Press the Personalization button in order to advance to the next option.
• UNLOCK DRIVER: IN PARK
• UNLOCK DOORS: IN PARK
• UNLOCK DOORS: AT KEY OUT
• UNLOCK DOORS: MANUALLY
Remote Activation Verification
Continue with the following steps in order to personalize the remote activation verification feature:
• LOCK FEEDBACK: BOTH
• LOCK FEEDBACK: OFF
• LOCK FEEDBACK: HORN
• LOCK FEEDBACK: LAMPS
• UNLOCK FEEDBACK: BOTH
• UNLOCK FEEDBACK: OFF
• UNLOCK FEEDBACK: HORN
• UNLOCK FEEDBACK: LAMPS
Delayed Lighting
Continue with the following steps in order to personalize the delayed lighting feature:
• HEADLAMP DELAY: 10 SEC
• HEADLAMP DELAY: 20 SEC
• HEADLAMP DELAY: 40 SEC
• HEADLAMP DELAY: 1 MIN
• HEADLAMP DELAY: 2 MIN
• HEADLAMP DELAY: 3 MIN
• HEADLAMP DELAY: OFF
Perimeter Lighting
Continue with the following steps in order to personalize the perimeter lighting:
• PERIMETER LIGHTS: OFF
• PERIMETER LIGHTS: ON
Mar 13, 2017 | 2008 Chevrolet Trailblazer
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
Blueish hue throughout picture, like a blue ghost a couple of inches to the right of objects on the screen
Your TV's Convergence may be out of line. To adjust this do the following.
1) Press the Menu button on your TV/Remote
2) Scroll through and select the "Advanced Features" Menu.
3) Select Blue Convergence
4) Use the V keys on your remote till the cross hairs are all lined up in the middle of the screen and the center one is white.
4a) You can use the "Video" button to switch between the red & blue cross hairs.
Dec 28, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Change my aficioDSM635 language
A. Press the {User Tools/Counter} key.
The User Tools main menu appears.
Note
? When the key operator code is set, the key operator code input
display appears when changing the default settings. Enter the
registered key operator code beforehand.
For key operator codes , see "Key Operator Tools", General Settings Guide.
B. Press [Copier/Document Server Features].
The Copier/Document Server Features menu appears.
C. Select the menu you want to set.
The setting display for each menu appears.
Reference p.83 "User Tools Menu (Copier/Document Server Features)"
D. Change settings by following the instructions on the display panel,
and then press [OK].
Exiting User Tools
A. After changing default settings, press [Exit] on the User Tools main menu.
Changes to User Tools are complete, and the machine is ready to copy.
Note
? You can also exit User Tools by
pressing the {User Tools/Counter}
key
Dec 17, 2010 | Office Equipment & Supplies
I HAVE A DOUBLE VISION, BETWEEN THE GREEN AND RED, THE GREEN IS SOMEWHAT WARPED OR ARCHED.
Please run the convergence feature on your TV. Its giving you double image because the red, green, and blue guns are disaligned. By running convergence it will realign the guns properly. You need to run the convergence feature at least once a week. Please note this is only for CRT rear projection TV's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to. Please refer to your TV's manual on how to do convergence and how to overlap the crosses because every CRT projection TV is different.
Jun 29, 2010 | Sony KP-51WS510 51" Rear Projection...
I have a flat screen Sanyo Model# ctl 2054 will a universal remote control work for this tv I don't have the orginal remote control?
Yes, a universal remote control should work on this TV since all remote controls utilizes infrared sensing technology. However, not all functionalities and features of your TV can be accessed using a universal remote control, thus only the basics like volume and channel controls but some advance features like menu setup might not work.
May 26, 2010 | Televison & Video
"convergence chip failure"
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 05, 2009 | Sony KP-43T70 43" Rear Projection...
Hi I have TV AKAI start projecting a red
rear projection tv can be crt or dlp, if crt, try to adjust red color using the customer convergence feature, you will find it in the customer menu usually under advance feature or video settings, some tvs will just give the convergence caption right on the menu listing. If this does not help then the tv might be in need of some convergence circuit repair, probably one of the power outs is damages and needs to be replaced. If it is a dlp if the red shade extends all over the screen or located in a certain area of the screen then i would have the tech check for light engine trouble, this is a common problem on some dlp systems.if i answered your question satisfactorily please leave your positive feed back. thanks
Aug 26, 2009 | Akai Televison & Video
Mitsubishi VS-60719 60" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
