Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Laser 72 wont fire up
I have a laser 72. its not firing up.\r\n
hit on button, wait 5 mins and the green light comes on, and the pump starts tapping, (calling for fuel or whatever). then after about a minute it goes to red reset light and the back fan kicks on for a few mins.
i have removed the filter, (its clean)
i loosened the bleeder screw (next to the filter cover plate,,i assume this is a bleeder)and bled it a bit. plenty of fuel coming out.
i removed the inlet tube to the burner and blew through it, its clear of blockage.
i removed the black hose and checked the internal fan...seemed maybe a lil stiff to me...but im not sure how freely it should turn...it didnt spin on and on after i flicked it with my finger but it moved semi freely and looked clean.
I have just been inside my 72 for the same reason. Have you cleaned the burner pot and heat exchanger lately? If not it is time. What makes these things work is a burner mat in the bottom of the pot that will eventually go bad. if this occurs you must change it out, if it looks good ( looks unburned) and whole and attached to the pot then your problem is with the igniter or with the combustion sensor or a clogged fuel pot inlet fitting. The first thing I would check is the easiest, disconnect the fuel line from the inlet to the pot, remove the screws and pull it out, it may be kind of stuck in there so a little rotation usually helps. When out, hold one end up to a light and see if you can see unobstructed light through it, if not, clean it out using a piece of wire or if you have access to a set of acetylene torch tip cleaners use those until it is good and clean, re-install and try that. If no good I would disassemble the burner pot and heat exchanger and give it a good cleaning and inspection. If you go that far there are a couple of things to watch out for. First is when you go to remove the burner ring it comes off in a counter clockwise rotation, there are three pins set in the pot that hold it in place and if they are carbon encrusted it won't want to turn and DO NOT I repeat DO NOT try to horse it off, you will break the upper burner ring mounting arms and I have been told by my parts guy that they are unobtainable now. I speak from experience, I did it and had to weld it back together, no big deal if you can but if you have to take it to a welding shop it will cost you a few bucks. My suggestion is to take a large flat blade screw driver or better yet a brass or steel rod about a quarter of an inch in diameter and go down along side the upper ring and LIGHTLY tap around the lower ring to try to loosen up the gunk and try again, keep this up as long as you have patience and hopefully it will come out. If not you can send it to a Toyo repair station or horse it out and have it fixed. When you get the ring out the next issue after a good vacuuming and cleanout is the igniter unit, it will be stuck and if you cannot turn it you can heat up the burner pot around it with a propane torch until very hot and let it cool and repeat a few times until you can get it out, ( I suggest either taking the pot outside or running your shopvac over it when you do it) if you break the ceramic it will cost close to a hundred bucks to replace. If you are still with me, now for the cleaning part, if the burner mat has lifted from the bottom of the pot anywhere, it must be replaced and it will be burned up in the places this has happened. Give it a good scrape down and shining up with sand paper until no carbon or old glue remains and vacuum clean and wipe it with a solvent until clean. The new burner mat comes with a tube of adhesive and it takes about half of it to secure the mat down, a thin even coat is needed with no puddling, use a small one inch chip brush to coat it and brush it all in even strokes in one direction and then 90 degrees off to create a cross hatch pattern. Place the burner mat down and using your fingers press it into the adhesive until you have covered the whole mat, do not leave any piece unpressed. At this point you can clean out the heat exchanger by flushing it out with a hose outside, be warned, it is messy, lots of carbon and soot come out so pick a suitable location like a cleanable sink or out back somewhere. One other thing, when you go to remove the large gasket that seals the burner pot top to bottom, take piece of rigid paper, like a cereal box, and carefully slide it onto it and back on, don't pick it up by any means, it will crumble and you will have to spend another thirty bucks or so. I have learned most of this from my local parts guy and from the school of hard knocks, so I hope this helps. JP
Posted on Oct 01, 2009
Forgot password to my kindle fire. How do I reset
1 Connect the Kindle Fire to your computer using a USB cable.
2 Wait for your computer to recognize the Kindle Fire device, and select the option that allows you to view the contents and data stored on the Kindle Fire.
3 Copy or move the Kindle Fire files you want backed up over to your computer's desktop or other location.
4 Right-click on the icon for your Kindle Fire located on your computer's desktop, and select "Remove" or "Eject."
5 Remove the micro-USB cable from your Kindle Fire. After you reset your Kindle Fire, you can follow these same steps to move your saved files back to the Kindle Fire from your computer.
Part 2 Reset the Kindle Fire
1 Tap on the "Quick Settings" icon on your Kindle Fire. The icon is shaped like a wheel, and is located in the status bar at the top of your Kindle Fire.
2 Tap on "More."
3 Tap on "Device."
4 Tap on "Reset to Factory Defaults."
5 Tap on "Erase Everything." Your Kindle Fire will reboot, and display a message that confirms the reset process.
When the Kindle Fire has finished resetting, it will reboot once again, and display the initial start-up screen.
Oct 02, 2014 | Tablets & eReaders
2001 dyna fxd just dies while riding. Have to wait about 5 mins. before it fires back up. Can anyone help?
hi i had a simular problem with my 98 fxd turn out to be the vacuim opperated fuel tap i blocked off the vac pipe to the fuel tap and put a high flow tap in the tank all you gota remember is to turn fuel on and off but it sorted out the cutting out good luck
Sep 18, 2014 | 2001 Harley Davidson FXDL Dyna Low Rider
96 bandit, wont start,will turn over but not fire up, have changed plugs, drained carbies, checked for spark, still not firing up, any ideas?
check fuel filter and shut off in float chamber , if you have spark and gas , still not firing check timing .
Mar 18, 2012 | 1996 Suzuki GSF 600 S Bandit
Have been having issues starting bike. Engine seems to be flooding for no apparent reason. e.g., this has happened multiple times.Started it today ( idling little low round 0.5k revs), let it run for 5...
A flooding problem is usually due to a problem with the foat and the needle/seat in the carburettor. This could be sticking open and allowing the engine to flood. Also, alowing an air cooled engine to run stationary for extended periods builds up considerable localised heat and this could be causing fuel to percolate and flood the engine. Back fire could be coming from a sticking valve - from the heat and a carbon build-up?
But first check the floats and needle and seats in the carb an shut off the fuel tap after shutting down the macnine.
Jan 16, 2011 | Honda CBR 250 RR Motorcycles
Hit the key it fires as soon as you let off the
sounds to me like the "pass lock" key sensor (anti theft) is dirty or failing it should throw a "P" code.
Mar 14, 2010 | 1999 Chevrolet Silverado 1500
Onece in a while turn over wont fire. runs great other wise
your injector or fuel pump may be going out, next time when you check the issue, check your distubutor again and making sure you getting sparks, if you do have sparks than it has to be your fuel problems.
Jun 25, 2009 | 1991 Honda Civic
The reset button comes on for laser 72
The thumping noise is the fuel pump starving for fuel. It sould like you are having a fuel problem. NO fuel, low fuel, dirty filter.
Tom Hawkins
hawkins111@gci.net
Jan 03, 2009 | Rinnai Toyostove Direct Vent Heater:...
Car wont fire
check fuel pump its in the petrol tank acessable from under the back seat through a cover
Dec 07, 2008 | 2000 Ford Focus
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
683 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
