Question about Mitsubishi WS-55819 55" Rear Projection Television
Need help on input settings. changed mode to watch a dvd, now we can't get it back to tv mode. only 3 modes are coming up - cam, dvd and dbs
    President:
  • Mitsubishi Master
  • 1,779 Answers
Try just pressing any channel, like 08 ect...If that doesn't work then go back into your menu and change the input that way.
Posted on Oct 01, 2009
I just purchased this DVD LG I'm trying to find out what channel to put it on to watch my DVDs on and I'm on DirecTV
There is usually a switch on the back of the DVD player to choose either channel 3 or 4. You will need to use the TV's remote not the direct TV remote. To change the source or input to the correct inpit mode on the remote select input then select the input mode that you plugged your DVD into ( tie. HDMI 1 or 2 ) then turn on DVD that should do it
Jul 26, 2015 | LG Televison & Video
I dont have cable.i was using this tv just to play dvds and i accidentally hit channel search. now i get a blue screen that says" plerase connect cable system or an antenna to the terminal on the back...
Hi:
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
May 17, 2011 | Televison & Video
I transfered from watching my sattelite tv to watching a dvd using the tv control. The dvd sound worked ok, but I couldn't get a pictue. Then I tried to watch tv again, but the vidio would not come in,...
Just in case, here's the 108-page user's manual for your TV:
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
Yor "NetCommand" TV remote is a wondrous thing, capable of throwing off anyone.
When the 'Device Selection Menu" is dispayed, and only when the device icon is highlighted,
does the key work, and it also only works when the remote is in "A/V Receiver" mode -
not in "CABLE or DBS" mode, nor "VCR" mode, nor "DVD" mode.
So, (1) set the NetCommand remote to "A/V Receiver" mode
(2) bring up the Device Selection Menu, using the key on the remote
(3) highlight the Satellite receiver input icon (highlighted with a Yellow outline)
(4) press GUIDE on the remote, to swap the analog digital setting.
Also displays ChannelView for Antenna 1 and Antenna 2 - you may have accidentally
set the TV to get its input from the wrong Antenna.
If your TV has lost memory of its DBS source, you may have to re-teach the TV (using the remote)
that the DBS (Digital Broadcast Satellite) input exists, and to which input its connected.
Refer to "Edit NetCommand, Add an A/V Receiver", pages 39-45 of your Owner's Manual.
Jan 31, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Im trying to set up my tv, it was given to me as a gift, my uncle was using it it works i can change the channels but when i try to work my dvd player with it, only the audio comes on the screen stays...
Please few things...
1- Make sure audio and video wires are hooked correctly in AV input of tv and you selected that AV input in tv with its remote.
2- Also check your dvd has not been set on progressive mode if you hook dvd player through yellow-red-white wires with tv.
3- if dvd player is set on progressive mode, then hook it with tv by component video input, red-green-blue for video and red-white for audio.
Hope this info will solve your problem.
Thanks.
Mar 17, 2010 | Toshiba TP55H60 55" Rear Projection...
Can I change input mode manually?
Try channel button to 1-2-3--99-98-1-2-3 up & down it should come between 0 & 1
Jan 21, 2010 | Sylvania SRT2232S 32" TV
Can't get it back to tv input - tv connected to 2 direct tv satellites. changed input to dvd mode and now tv mode won't come back up. went to menu to change input and still cannot get tv to come up
You set may be set to Home Theater mode.
I think it is in the advanced menu.
Set home theater to off. This will fix the input on the television to input one, no matter what you do.
I hope that this helps you.
asnowman
Oct 01, 2009 | Mitsubishi WS-55819 55" Rear Projection...
No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Sep 13, 2008 | Symphonic ST420FF 20" TV
How Do I Get a DVD to Work with This TV?
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Feb 16, 2008 | RCA G32665 32" TV
Bizzare Color Problem
I normally find that the DVD is either in the progressive scan or interlaced mode. If the DVD is in analog inputs (video inputs), then, it should be in the interlaced mode. If the DVD is in the component input, then, it should be set to the progresive mode. On older DVDs, the switch to turn it to the proper mode is on the back or bottom of the DVD. Newer units are on the remote that says progressive or on the menu of the DVD. The owners manual should have instructions on how to change it.
Sep 01, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Mitsubishi WS-55819 55" Rear Projection Television Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
