Question about Samsung SYNC SGH-A707 Cellular Phone
My cell phone is dead.
At first the regular charger wouldn't work so instead I used my car charger. Now my car charger is refusing to work and my cell phone is officially dead. It will turn on so much as to greet me then will shut off. Please help, how do I fix this??
  • 2 more comments
  • gfdgdf Dec 22, 2007
    my phone wont charge anymore. its a samsung sync and refuses to charge
  • bria1506 Jun 25, 2008
    same phone, same problem.
  • Anonymous Jun 26, 2008
    cell phone dead won't turn on or charge
  • mbruce3 Jul 15, 2008
    Original charger will not charge the phone. It is completely dead!!
It's actually quite simple - rechargeable batteries are NOT permanent - eventually, they will refuse to take a charge - buy a new battery for the phone.....
Posted on Jan 18, 2009
If it's not specifically made for your phone, it wouldn't work. some chargers may have the same charger jack, but were'nt made for your model of phone.
Posted on Dec 27, 2007
My phone stopped charging and it wont work where the charger part is.
get a new charger..if it dont work..your plug on your cell needs repair
Jan 08, 2014 | Nokia Lumia 820
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
I have had 4 pantech jest phones and it wont charge!!!! i had it plugged in then i thought it was charged fully cause the bars were full when i took it out.....BAM!!!! i shutt of!! im sick of it i had 4...
Make sure you're using the Pantech charger you got with your phone. I had this problem, got a new one, and realized I'd been using my old charger charger. Plugged it in with the wrong charger, it wouldn't work. Plugged it in with the Pantech charger, it started charging up and worked fine again.
Dec 27, 2010 | Cell Phones
Completely dead and won't come on
These type of problems are hard to diagnose. But first start with power. If using the home charger, try the car charger. If both do not work, check the battery to see if it's seated correctly. Are you using an OEM "original equipment manufacturer" charger. If you use a charger bought from a 7-11 then you may have burnt out part of your phone. Use a friends battery that has a phone like yours. If that works and it's out of warranty, buy a charger and charge batteries on a chrger, then insert them into phone each time. Got insurance on phone?
Sep 15, 2010 | Nokia E63 Cell Phone
I just bought a motorola E815 cell phone and it will not charge
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.Hope this helps!
May 08, 2010 | Motorola Mobility E815
Won't acknowledge the charger!
Either you have a bad charger, bad battery, or the charging port on the phone is bad.
1. Try a different charger. (Like your car charger instead of your home charger. Or your buddies charger) If one works and one doesn't, you found your problem chargers do go bad.
2. If this wasn't your problem. Next I'd buy another battery - usually you can get one for less than $10 online. If the new one works, woohoo problem solved toss the bad battery.
3. If the new battery does the same thing, its the phone. If it's verizon and less than 12 months old, call them - its probably under 1 yr warranty they might replace it free - as long as the white sticker near the battery is still white (water detection is pink/red). And it's not crushed or dented/damaged.
Dec 01, 2009 | UTStarcom Blitz Cell Phone
Using my data cable to charge my cell phone
hi thanks for using fixya!!
The data cable will not work to charge your samsung e900, you have to purchase a compatible charger for your phone.
Regards!
May 07, 2009 | Samsung SGH-E900 Cellular Phone
Phone wot charge
I reccomend you take out the battery, and put it back in after 2 minutes. Next, if you are using a car charger, use the home charger instead. If you are using the home charger, use the car charger instead. The charger may be broken.
Nov 17, 2008 | Sony Ericsson K850i Mobile Phone
Samsung SYNC SGH-A707 Cellular Phone Logo
202 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
