Question about Acer Aspire 9500 Notebook
Shuts down after I press the start button - Acer Aspire 9500 Notebook
  • 788 Answers
Check your power connection on the side of the laptop.
Check the power supply and see if you are getting power to the noebook.
If you are getting power to the notebook, remove the battery and power up the unit. If the unit runs, try replaceing the battery while unit is running.
Posted on Oct 01, 2009
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Computer will not start
Press power button down for 5seconds until the computer shuts down. Remove power cable, press power button down 10s. Connect cable, try to restart.
Aug 17, 2012 | Dell Computers & Internet
Shut down in sleepmode by mistake, how to awaken?
Press enter twice or press power button to awake.
Thanks,
satheesh
Jan 20, 2011 | Computers & Internet
How do i reboot my laptop? its a acer
Use Start button and then Shut down then choose restart from the options if using Windows. Use the reboot command to reboot Linux. If frozen, press the power button for a while to shut it down and restart it by pressing the power button again.
Nov 26, 2010 | Computers & Internet
I press the power off button and it doesn't power off
You should never power down by pressing the power button unless your system is deadlocked and won't respond to any other actions. Powering off in this fashion can cause you to lose data, corrupt files, and improperly shut down Windows.
Nonetheless, if you are in need of shutting down the laptop in this fashion you must hold the power button instead of only pressing it. You'll find this in the power settings of the device. Honestly, the power button may even be set to do nothing, which is possible.
To properly shut down your new Pavilion laptop, which should be running Windows 7, follow this process: Click Start > Shut Down
Start is now simply a circular Windows icon in the bottom left corner of the screen and shut down has an arrow pointing down next to it. Click the words shut down instead of the arrow which will bring up other power save options.
Oct 17, 2010 | HP Pavilion dv7-1245dx Notebook
What button to press to reboot laptop acer aspire 2930
You turn it off ...then back on to reboot.
click the start button - select turn off computer
Mar 24, 2010 | Acer Aspire 2930-4661 Notebook
Button monitor problem
Disable all startup items. Click on Start> Run> Type msconfig then press enter. Click on the Start Up Tab the click on Disable All. Click close and restart your computer.
Your system should be starting up faster compared before.
Feb 08, 2009 | Dell Microsoft Windows XP Home Edition
I am 56 years old computers are not my generation. just got a new computer. and am trying to close it but it would not close . what I did is close the the monitor. and then pressed the button off of the...
You have to click the Start button and choose "Shut Down " and click the mouse on that. If that does not work, try pressing Ctrl + Alt+ delete simultaneously. What they call the task manager will come up. choose Shut down and click on it. It should shut down
Nov 08, 2008 | Acer Computers & Internet
My 6030 has suddenly shut down!
it shutted down because (maybe)
of the folowing reasons:
1.) Error
2.) You have overloaded it,
3.) Full Memory.
try removing the battery (5 mins)
the put it back again.
then press on..
if it wont want to start.
charge your cellphone.
then try pressing the on button
Nov 02, 2007 | Nokia 6030 Cellular Phone
Acer Aspire 9500 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
