A small amount of water was spilled on the keyboard of our Toshiba laptop. Now, there is a short circuit between b and t, a and 1, and ` and 2. We tried to replace the keypad but that didn't fix it. The computer works fine with a wireless keyboard. Any idea on what's wrong?
  • 788 Answers
If you replaced the keyboard and you are still recving and identical error or symptoms, the problem is in the motherboard.
If you replaced the keyboard with a new keyboard.
Posted on Oct 01, 2009
How do I dry it out after tap water spill?
Leave face down on a clean cloth so the water will run out. You may be lucky after leaving it off for 24hours.
Oct 18, 2014 | Computers & Internet
Spill a small amount of water on keyboard no machine shuts off shortly after it is turned on
its not a big problem as i think so ....if u have immediately turned on the pc after the that incident.some shot=rt may have occured...remove the batteryimmediately and its better to keep your machine outside i.e in the sun for saome time so that the content of water gets dried up...this may work ..all the best
Sep 12, 2013 | Computers & Internet
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
I spilled my TOSHIBA SATELITE C660 with very small amount of pure water. some of the keypads had stopped working. how can I revive these dead keypads without replacing the entire keypad?
Short answer is... you can't, The circuit part of the keyboard is just a couple of printed mylar sheets overlaid on top of one another - then "manufactured" into the entire keyboard (by adding keyswitches, keys, and bottom tray, etc. You can take it apart, and you may well be able to clean it and fix it - but you'll never be able to put it back together and have it fit and work the way it used to. Replacing the keyboard is the easiest and the cheapest thing to do.
Jul 30, 2011 | Toshiba Satellite A55-S106 (PSA50U0NE02E)...
Spill water on my macbook air, and does not turn on
gone with the wind....or shall i say....water....
dump it in the trash bin....
all liquids are enemy of any IC equipments.....
(many have this dirty habbit of drinking Tea/Coffee/Beer etc while working with their notebooks/laptops.....)
on PC..... the liquids normaly spill on to the keyboard/mouse which is seperate from the CPU...
can replace the keyboard of a PC with just few $$$
but with notebooks the main circuit/motherboard is just below the keyboard.....
once a liquid falls...it just goes thru the holes on the keyboard....and short circuits the ICs...chips...etc
Apr 20, 2011 | Apple MacBook Air
Spilled tea on computer 7 repair technician says we need the motherboard
Did you saw the tea entering on the main motherboard? Did it worked after tea spilled in it? Water or any solution which contains water in it, which have short circuit on electronic boards, so it might had been damaged. Other important thing is, the computer motherboard contains microchip which is most likely to get damaged in small presence of small amount of water entering in it. So think twice about the amount of spill and then apply some idea, is the technician giving right diagnose, or you need another tech for this problem?
Mar 04, 2011 | Compaq Computers & Internet
Touch Pad on my laptop is not working
Follow the guide below to tear the laptop down, you are extremely fortunate that the device is even working. Electronic sircuits and water have never been a good match, and your keyboard and touchpad are essentially just large electronic circuits. There is probably some water still somewhere under the keyboard and it is probably in contact with the tochpad cable or socket. When you have the keyboard off, use a hair dryer on warm and completely dry out all components and make sure all the small flat cables are tight in their sockets.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Dec 13, 2009 | Toshiba Satellite A100-S8111TD Notebook
Keyboard suddenly got weird
A keyboard is nothing more than a collection of small switches under the keys. A liquid will short out between the contacts of the switches and is the same as hitting the key. There are still fluids inside they keyboard circuitry. By using it like this it can short out the keyboard and ruin it. It needs to be taken out and cleaned and dried throughly before it is ruined. (might already be ruined). You can usually find replacement keyboards on places like ebay.com
Oct 01, 2009 | Computers & Internet
Toshiba Satellite a105-S2716 keyboard doesn't work. Soda spilled on it. External USB keyboard does work. How do I fix it?
I think your Toshiba got grounded or short circuit inside. Better also to use USB Keyboard, it works.
Aug 18, 2009 | Toshiba Satellite A105-S2716 Notebook
Toshiba L355D-S7815 - Spilled Juice - Short Circuit
Flip the lid open and flip the laptop (opened) and set it on a towel or something. It might take a week or a bit more to dry out. But you might be ok once it does dry out.
Although the best thing to do is to take it apart. And use a safe cleaner for circuit boards like alcohol (not wood alcohol).
Since you supplied power while it was wet. You could have have done permanent damage to the intergrated circuits. But let's hope not.
Jan 30, 2009 | Toshiba Satellite Laptop with AMD Athlon...
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
