First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Was this helpful?
Yes
No
Popular Solutions for Panasonic CQ-VD6503U Car DVD
I have a Panasonic CQ VD6505U I want to know how to activate the Navigation Do I need a disc to...
(More)
I have a Panasonic CQ VD6505U I want to know how to activate the Navigation Do I need a disc to load? I bought the truck with it already installed, everything works except navigation... Thanks Gerry If I do need a disc where do I get it? Thanks
it stiil works fine but the screen is distorted,ive noticed that it is worse when the tempeture is...
(More)
it stiil works fine but the screen is distorted,ive noticed that it is worse when the tempeture is hotter out side.it gets less fuzzy when its cooler weather.
