Question about Frigidaire FEF336BC Electric Kitchen Range
Fridgidaire elctric oven with the touch control pad
The electric oven wont shut off when we push the off button on the control pad
  • 1 more comment
  • Anonymous Jan 04, 2008
    is been doing cleaning for almost more than 4hours and the sound like fan not stopping. Turn off and on the electricity and the problem still exist. door locked. please help what should I do?
  • cherios Jan 06, 2008
    oven won't shut off from control pad, have to shut oven off at breaker panel and if we turn breaker to oven on, the oven goes on again and still won't shut off and it seems to be only the top oven element
  • relliott6 Jun 25, 2008
    bottom element in oven wont shut off unless we turn the breaker off at panel. when i turn the breaker back on the element turns back on. have to keep breaker cause oven will not stop heating.
    Novelist:
  • 184 Answers
MOST OVENS TODAY HAVE THE CLOCK/CONTROL AS ONE UNIT THAT HAS THE RELAYS THAT TURN ON THE BAKE/BROIL CIRCUITS. SOMETIMES THE RELAYS FUSE THE INTERNAL CONTACTS KEEPING THE CIRCUIT RUNNING AFTER THE MICROCOMPUTER SHUTS DOWN THE CIRCUIT.
THE OVEN CONTROL WOULD NEED TO BE REPLACED.
IT IS ALSO KNOWN AS THE CLOCK.
OCCASIONALLY, THE MANUFACTURER WILL HAVE A SEPARATE RELAY BOARD AND CONTROL BOARD. FIND OUT WHICH CONFIGURATION YOUR RANGE IS AND REPLACE THE PART THAT CONTAINS THE RELAYS.
Posted on Apr 04, 2008
BAKE & CLOCK BUTTONS DO NOT REGISTER WHEN PUSHED- CLEAN & BROIL BUTTONS ARE REGISTERING
If your oven is a touch pad model then the pads are bad. the touch pad assembly will need replacing. Sometimes you can remove the ribbon cable and reinsert it. It sometimes will make them work but not very often. Make sure the power is off first. Remove the control panel. You will see the ribbon cable. There will be small tabs on each side of the connector plug carefully unclip these and remove the cable and reinsert it. Be prepared to replace the panel.
Nov 25, 2013 | Whirlpool RBS275PD Electric Single Oven
I am getting an F0 error code on my GE JTP15. It was working and then just shut-off. Then the error code appeared. I removed power for 30 minutes but the oven control did not reset.
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 30, 2011 | GE JTP15 Electric Single Oven
Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
May 27, 2010 | GE Profile JTP56 Electric Double Oven
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
Exactly the same problem. My oven is 11 yrs old instead of 10
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Help with dobble oven
clean the ribon conecto from the touch pad to the controller, use an pencil eracer to rub the ribon contacts
Dec 24, 2008 | Jenn-Air JJW8230D Electric Double Oven
My GE oven wont stop beeping it has an FO on the screen. All the buttons will not press. I just bought the house and have no idea if its done this before. Please help!!!! Chelsea
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Dec 12, 2008 | GE Profile JTP18 Electric Single Oven
Fridgidaire Electric Oven Clock
try holding the clock pad/button in for 3-5 secs it sould beep and remain on . youve turned the display off. that should reset it. if not give a call to the manufacture. they get a lot of these calls when time changes back/ahead
Mar 12, 2008 | Ovens
Frigidaire FEF336BC Electric Kitchen Range Logo
350 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
