Question about Sport & Outdoor - Others
Our 99 Yamaha Grizzley 4 wheeler turns over but has no spark. We have replaced the rectfier assy and the ignition coil assy but still have no spark. It was running fine earlier this summer but then just quit and will not start. What would you suggest that we should look at to get spark.
  • annvanbockel Oct 01, 2009
    Yes, we replaced the spark plug and checked the wire with a meter.
    President:
  • Sport & Outd... Master
  • 1,714 Answers
You have tried new plugs...right? I didn't seeyou mention it. Have you checked the plug wire? With a meter?
Posted on Oct 01, 2009
  • Craig Butler
    Craig Butler Oct 01, 2009
    How's the battery doing? Is it turning over strong? Have you done an inspection on all the wiring?
I have a Yamaha moto4 350 that will, at best, start and idle but dies immediately when I give it any gas. The carb is new, any idea why it won't start? Or when it does, why it dies when given gas
Hi, Kieth and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
yamaha moto 4 350 update
No Spark Diagnosis Motorcycle 4 Wheeler Starting Issues Using Multimeter
http://www.maultechatv.com/techguides/Service%20Manuals/YAMAHA/Bruin%20350.pdf
Dec 11, 2015 | Yamaha Motorcycles
1985 Yamaha three Wheeler 50 cc has no spark been setting awhile
Hi, Terryjoe if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
Honda TRX 70 No spark fix try this FIRST
http://www.oscarmayer.net/atc/manuals
http://www.shareol.com/?s=1985+Yamaha+tri+zinger+50+
Dec 05, 2015 | Yamaha Motorcycles
1987 kawasaki k305 no spark rewired put in a yamaha 4 wheeler
go back and chec for proper grounds or wiring flaws--a clymer manual has diagrams and rebuild details--is battery at 12.6v--a coil ignition cant have less then this--are terminals tight enough
Jul 31, 2014 | 1982 Bikemaster Kawasaki Kz305b Csr...
Fixya review
Hi, Anonymous and the usual suspects are:
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and CDI box.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/38102-00-r6-turns-over-but-no-spark.html
http://pnwriders.com/threads/99-r6-wont-start-no-spark.138195
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 04, 2014 | Yamaha YZF-R6 Motorcycles
Electric is working and starter is clicking over. Getting no spark out of all 4 plugs. checked all wiring and grounds, all good. What should I check or do?
Hi, Kevin and the usual suspects are:
2003 2004 Yamaha YZF R6 Service Manual R6 Moto Data Project
Oct 14, 2013 | 2003 Yamaha YZF-R6
Hi i have a 99 r6 and i have no spark to any of the plugs. help please !!
Hi, Jonathan and the usual suspects are:
http://www.r6-forum.com/forums/57-garage-mechanical-help/335658-no-spark-troubleshooting-nutshell-may-still-need-help.html
1999 2002 Yamaha YZF R6 Service Manual R6 Moto Data Project
Project Yamaha R6 Part
Yamaha YZF 600 R6 5SL 05
Aug 22, 2012 | 1999 Yamaha YZF-R6
2001 xjr 1300 will not start their is no spark at plugs
2. Discharged battery, needs to be 12.5 volts or better and be able to pass a "LOAD" test, your battery may show 12.5 volts but has little or zero amps and must be replaced.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or CDI or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.yamahaxjrownersclub.com/phpBB3/viewtopic.php?t=39749
How to diagnose no spark situation on motorcycle
Yamaha XJR1300 99 Service Manual
Yamaha XJR1300 Owner Manual
Feb 25, 2012 | 2001 Yamaha XJR 1300 SP
Im losing spark after my yz 125 engine warms up, why?
Hi, Jeffreyo76 and the usual suspects are:
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or electronic control module or CDI box.
Dirt Rider Magazine
99 yz 125 no spark Yamaha 2 Stroke
YAMAHA YZ125 Owner Service Manual
May 19, 2010 | 2004 Yamaha YZ 125
1999 TTR 250 Wont SPARK...
have you replaced the spark plug it may be stuffed
hope this helps
Jun 18, 2009 | 2002 Yamaha TT-R 250
Yamaha timberwolf 4x4 carberator issues
Firstly, if you are not a mechanical person you should never buy a vehicle that does not run.
However, here are some basic tests.
1. Connect a good battery.
2. Remove the spark plug.
3. Turn the motor using the starter motor or kick starter.
4. check for spark by inserting a new plug into the plug cap. (make sure the plug is grounded).
If the motor turns freely and there is spark, chances are good that the motor will run. This does not mean that the motor is in a good condition. Only with the motor running will you be able to know for sure.
You will now have to source a carb and fit it to the 4 wheeler.
Fitting the carb is not too difficult. Check that the intake manifold is not perished or torn, and remember to use the airfilter.
Enjoy the ride !
Jon
Mar 01, 2009 | 2003 Yamaha YZ 250
Sport & Outdoor - Others Logo
79 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
