Question about Juki DDL-8300
Which way to put the needle in the Juki, The
Which way to put the needle in the Juki DDL lockstitch. The needle has an "indent" in its shaft. I know the thread goes through from left to right. Where sits the indent? Since I changed the needle, the threads breaks.
  • 208 Answers
The indent is called the scarf.
The scarf will be at the 3 o'clock position and, if you look closely, you will see the hook pass the needle at the scarf.
Posted on Oct 01, 2009
Juki 8300N
Dear Rosemarie,
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
Cheerup and Be Happy always
Mar 27, 2008 | Juki DDL-8300
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
Does This model have a reverse stitch option?
hello there
depended on model , the all JUKI LOCKSTITCH MODEL have a reverse stitch but normal model was by hand and with control box was both automatic and manual.
DDL-8700 was manual reverse stitch.
best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Aug 12, 2014 | Juki DDL-8700
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
Puller for Juki DLL 8700-7
hi there
please we need more explain for what puller you need ?
if you mean rear puller you can use RACING PULLER for lockstitch machine model PL - P2 .
if need more help please email me at aabozid@hotmail.com
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
Jan 22, 2011 | Juki DDL-8700
The needles I have are round shafted, ( no flat side ). Which way do I face the small recess where the eye is ? My machine was given to me. It's self oiling. What type of oil should I use? And where can...
hi there
concern needle attached if your machine lockstitch machine you are use DBx1 and easy to attach just keep in your main at any machine the small flat must be obosit saide from you threading the thread.at lockstitch machin small flat must be at ur right hand and the long at ur left hand .concern oil you can use juki defrex No.1 or light clear oil for industerial sewing machine.
Oct 28, 2010 | Juki DDL-8300
I have a Juki DU 141NH industrial sewing machine. I just had it serviced. I had to put a new bobbin in and now the needle is not catching my bobbin thread. Please help!
Be sure you have the proper needle - it is longer than standard needles, plus be sure that you put the needle in from left to right - not...front to back.
Oct 07, 2010 | Juki DDL-8300
Juki DDL-8300 Logo
753 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
