Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer drum wont turn
I have had my electric maytag dryer for 2 years and yesterday the drum stopped turning and it is not heating up. The controls are still working. We took it apart and realigned the belt, which was in good condition, but it still will not work. What else could it be?
Christie
  • d29irene Apr 03, 2009
    My maytag neptune dryer will not turn, but it continues to get hot
  • 833 Answers
These units use two circuits to operate. It is entirely possible that the circuit breaker for one is open. The breakers are linked units...generally 30-40 amperes. Turn both off and then on.
Posted on Dec 21, 2007
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer (LDE5914ACE) loud slipping/thumping sound
yes, it's called a blower wheel... it is what blows the air into the dryer to blow out the humidity through the vent... it has a D fitting and as you use it, the D rounds out and the 'squirrel cage' stops spinning and begins to slip... if you continue to use the dryer without replacing this, you could burn up your dryer motor... it will just over heat....
Mar 19, 2010 | Maytag Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Gas Dryer SDG515DAWW - heating stopped
if it dont come on in 30 secs replace it
Dec 30, 2007 | Maytag MDG2706A Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
230 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
