Question about Nikon D70s Digital Camera
Cannot take picture, push the button - nothing happens r12 flashes on the little screen
My freezer works fine. The fridge only gets a little cool. There is a grocery saver button and a acceler ice2 button in the fridge. If I push the acceler ice2 button it will get cold enough but the button...
I would have a apliance guy come check it out, if its an old fridge it probly needs to be recharged with freeon or r12 but r12 is illegal to use withought liscence and they dont use r12 in new fridges anymore. Good luck.
Aug 27, 2014 | Refrigerators
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Nikon d300 won't take pictures
Try to autofocus first by half press the shutter button, after focus confirmed then fully push the shutter button. Basically camera won't take picture if the focus not focused correctly.
Jul 21, 2013 | Cameras
I turn the controller on and the Ring of light keeps spinning around. The Xbox opens to the start screen but no matter what button I push, nothing happens, Just received the Xbox today.
make sure that your controller is sync with the box properly, there is a little white button on the top of the controller and the same picture white button on the front of the xbox, push 1 and then the other and they should find eachother
Feb 27, 2010 | Microsoft Xbox 360 Wireless Controller
Nikon coolpix s210 Not taking pictures
It sounds like you should try a new set of batteries in the camera. I have a similar camera and the flash is the first to go when the batteries are dying.
I hope this helps,
Eric
Jan 19, 2009 | Nikon Coolpix S210 Digital Camera
Flash problem
I believe you're pushing the wrong button. The way to turn the flash on/off is to push the top part of the ring that surrounds the "FUNC SET" button. This is the same ring that you push left/right to scroll backward/forward through the pictures you've already taken. Similarly, you push the bottom of that ring to turn the "macro" function on/off. Hope this helps.
Nov 11, 2008 | Canon PowerShot A630 Digital Camera
Camera stopped taking pictures.
well, I followed some other advice for another's problem. The suggestion was that the display button had been accidentally pushed. This was right on! I kind of thought it was something like that. I was asking my wife and kids if anybody had pushed any buttons. Never happened before. Kind of embarrassing, but the computer makes these cameras so complicated. My old eyes can barely see all the logos on that little screen. Thanks for being there, guys!
Cheers....theoldhogger
Mar 17, 2008 | Canon Cameras
Freeze up
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
Feb 22, 2008 | Televison & Video
Nikon D70s Digital Camera Logo
169 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
