Question about Garden
Placing the drive belt back in place
Do i need to un bolt the motor to slide the belt back in its place
  • 80 Answers
Check and see if there is a idler pulley. You should not have to unbolt the motor.
Posted on Oct 01, 2009
How to replace drive belt
you have to un bolt pto clutch (diconnect plug first)and drop off crank
put brake pedal down lock in place to give belt slack
remove snall pully on crank ( if rusted on remove 4 motor mount bolts and raise engine to remove belt.
reverse take off plan to install new belt.
Sep 01, 2014 | Cub Cadet Garden
I need to know how to change the drive motor belt on my Proform XP 542s. I have the new motor drive belt. I've marked the position of the bolt that holds the motor in place. How do I free the other end...
first you must mark the bolts that puts tension on the w/belt.then lossenthen almoct all the way . you need to relieve the tension on the w'belt. then remove the bolt that holds the front roller in place then the drive motor. slip off old installnew then tighten the front boltto wher you found it then with a little help move motor to oringinal spot tighten motor and then the back bolts
Mar 17, 2011 | Proform XP 542S TREADMILL Drive Motor
How to put on belt on motor
some where onthe belt their is tensioner brackey that has a bolt that can be loosened and slide down wards and the belt can be taken off . but their is a ketch you hace to get a tensioner ber that fits into the slot onthe bracket and you have to pull brack back to its proper place to tighten the new belt back into place. note: make sure that the belt goes back the same way it came off.
Dec 17, 2010 | 1994 Geo Prizm
Water pump going out how do i replace it
  • Removal of the Fan Shroud and Drive Belts
    • 1 Drain the cooling system. Place a waste oil collection pan underneath the petcock valve on the lower corner of the radiator. Open the petcock valve to drain the system.
    • 2 Remove the bolts that connect the fan shroud to the radiator core and remove the fan shroud.
    • 3 Loosen the alternator adjustment bolt and slide the alternator toward the engine. Remove the drive belt.
    • 4 Loosen the adjustment bolt for the air conditioning compressor, and slide the compressor toward the engine. Remove the drive belt.
    • 5 Loosen the adjustment bolt on the power steering pump and slide the pump toward the engine. Remove the drive belt.
  • Removal of the Water Pump
    • 1 Disconnect the bypass hose from the water pump by loosening the hose clamp and pulling the hose off the fitting.
    • 2 Remove the bolts that connect the water pump to the engine block, and remove the water pump and engine fan as an assembly.
    • 3 Remove the four retaining nuts that connect the fan assembly to the water pump. They will be located between the fluid coupling and the water pump pulley.
  • Installation of the Water Pump
    • 1 Attach the fan assembly to the new water pump by sliding the pulley then the fluid coupling onto the water pump and reinstalling the retaining nuts.
    • 2 Clean any old gasket material off the water pump mounting surface on the engine block.
    • 3 Place the new water pump gasket on the water pump mounting surface.
    • 4 Slide the new water pump into position and reinstall the mounting bolts.
    • 5 Reconnect the bypass hose by sliding the hose over the fitting and tightening the hose clamp.
  • Reinstalling the Drive Belts and Fan Shroud
    • 1 Reinstall the the drive belts for the power steering pump, air conditioning compressor and alternator. Tighten the adjusting bolts.
    • 2 Measure the deflection of each belt to make sure the belts are properly tightened. Measure deflection by placing a straight edge along the belt against the accessory pulley and the water pump pulley. Push down on the belt and measure the distance between the belt at the midpoint and the straight edge. It should be between 1/2 and 1/4 inch. Any more and the belt needs to be tightened. Loosen the adjustment and slide the accessory away from the engine to tighten.
    • 3 Drop the fan shroud into position and reinstall the bolts that secure it to the radiator.
    • 4 Close the petcock valve on the radiator and fill the cooling system with fresh coolant.
    • 5 Run the engine and visually inspect for leaks.
  • Dec 15, 2010 | 1992 Toyota Celica
    How to remove alternator on a 2005 range rover
    Hi
    Click here
    the link above should tell you all you need to know if you get stuck or have any problems give me a shout back ok
    Oct 26, 2010 | Land Rover Range Rover Cars & Trucks
    How to replace the alternator on a 2003 Mazda MPV
    Disconnect the battery at the positive terminal by turning the bolt counterclockwise. Disconnect the alternator's terminal by turning the nut counterclockwise and removing the loop from the terminal bolt. Store these connectors away from the battery.
    Remove the belt by pressing on the tension pulley arm firmly, then sliding the belt form underneath the idle pulley wheel. Release the tension pulley and the belt will slacken; it can then be removed from the alternator pulley wheel.
    Remove the alternator by turning the mount bolts counterclockwise, then sliding them out of the mount arms. Some models may have mount bolt heads that must be held in place with a wrench while turning the nut. With the mounts free, the alternator can be exchanged for a new unit. Position the new alternator into the mount arms and slide the mount bolts into place, locking them down with the nuts turned clockwise.
    Wrap the drive belt around the alternator pulley wheel (groove side down), then press the tension pulley arm and slide the belt back under the idle pulley wheel. Release the tension arm and the belt will automatically adjust to the proper tension.
    Reconnect the alternator's terminal loop by placing it over the bolt and turning the nut clockwise. Connect the battery by turning the positive terminal bolt clockwise.
    Oct 21, 2010 | 2003 Mazda MPV
    I need to replace the drive motor belt
    Take off the plastic hood that covers the motor and moving parts. There will be two bolts that you will need to be loosened that connect the motor to the frame. After you have loosened those you shold be able to slide the old drive belt off and place the new one on. Pull the motor tight and tighten those bolts.
    Aug 17, 2010 | Nordic Track Exercise & Fitness
    How to remove and replace a motor belt on proform
    Hello there. To replace the drive belt (motor belt) follow this procedure.
    1)Remove power to the machine
    2)remove the hood cover (3 screws on the rear of the cover)
    3) loosen the adjusting bolts for the walk belt located on the opposite end of the walk belt from the hood assembly. Loosen the adjusting bolts 10 full revolutions. This will loosen the walk belt.
    4) You should then walk the drive belt off of the front roller/pulley assembly by pushing the belt to one side while turning the motor. If you are nable to do this you will need to loosen the 2 bolts holding the drive motor in place.
    5) After removing the drive belt you can then slide the drive roller to the side out of the frame and it will slide out the other side of the bracket. This will allow the belt to be removed from the front roller and be replaced.
    If you had to loosen the bolts holding the motor you will need to retension the drive belt by pulling the drive motor back while tightening the bolts. This will require another person to help tension while you tighten the bolts.
    You can then retension the walk belt using the adjusting bolts and retightening them 10 revolutions.
    Good Luck Tim
    Dec 13, 2009 | Exercise & Fitness
    Belt amana washer replace mod lw6501w2
    I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
    1) Unplug the washer
    2) Slide the washer away from the wall about 12"
    3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
    4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
    5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
    6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
    7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
    8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
    Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
    Slipped belt
    look at the fixing on the motor you have to undo the bolt and it slides in to alow you to put the belt on then slide motor back and nip up the bolt
    Jul 19, 2008 | Hotpoint Washing Machines
    Garden Logo
    13 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
