Question about HP PhotoSmart 7760 InkJet Printer
Printer creates a shadow effect on a vertical line of printing
SOURCE: printer vertical lines
Looks like mark on drum.. Change the toner cartrige .. If the printer is older, could be that the exit rollers are worn out..
Posted on Nov 17, 2007
  • 186 Answers
SOURCE: HP 2600n Printer Problem
Sounds like the fuser assembly needs to be replaced. This is a supply item that you can order from HP
Posted on Sep 26, 2008
Ranjanraj
  • 15 Answers
SOURCE: samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Posted on Dec 23, 2008
  • 88 Answers
SOURCE: printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Posted on Mar 20, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: the printer is printing dark vertical line on the
90% or more of the time on this printer dark lines are coming from your toner/drum cartridge. You can verify this by changing cartridges if you have a spare. If you don't then remove the cartridge and look at the colored cylinder in the cartridge and see if the same "lines" are on the cylinder that are on your prints. This will tell you for sure that the cartridge is bad.
Posted on Dec 13, 2009
Why is my Epson WF 2530 double shadow printing?
Allen, that's very unusual. I've been using a workforce printer for years, and haven't ever seen anything like that.
What paper are you using, and what paper setting in your computer?
When you rand a nozzle test, were the nozzle lines even, or did some look kind of out of place? (a deflected nozzle will give that gosting effect, and "underhead cleaning" is the answer)
May 01, 2015 | Epson Office Equipment & Supplies
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
When printing a new page I get a "shadow like"
Clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Hope this helps.
Shane
Feb 08, 2011 | Brother MFC 7420 All-In-One Laser Printer
I've been having problems with my Epson 7600 large format printer, I recently took it all apart to unblock the light black tube. I reassembled the printer and everything is back to normal apart from I now...
The most common cause of horizontal banding is generally missing, deflected or clogged nozzles. To see if this is the cause you should first print a nozzle check and examine the printout with a 10x or better eye loupe for any missing or deflected nozzles. If nozzles are missing or deflected you will need to perform cleaning cycles to recover these nozzles. Once all missing nozzles are recovered try printing your document again.
If no nozzles are missing or deflected, check that you are using the correct driver settings for the type of media you're printing on. Also try printing at a higher resolution and turning high-speed (bi-directional) printing off.
The most common cause of vertical banding is over-saturation of the media, usually created by paper "rippling". To correct this effect, decrease the saturation and lower the paper suction. If vertical banding is still apparent print the image with high speed off (uni-directional). If this corrects the issue, align the print head, as described on page 5-6 of the Users Guide.
Jan 12, 2011 | Epson Stylus Pro 7600 InkJet Printer
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Go to the FILE DROP DOWN MENU
  • Select SERVER PROPERTIES
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Jul 28, 2009 | Tally Line Matrix T6050 Printer
Printer output has shadows, blurring, streaks, lines, poor color
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Samsung ml-2010 printer prints vertical lines on the page
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Printed lines shift to left and double images
Are the lines vertical? Have you tried to align the printheads? This can be done using your printer's installed maintenance software.
Mar 28, 2008 | Office Equipment & Supplies
HP PhotoSmart 7760 InkJet Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
