Question about Maytag Neptune MAH5500B Front Load Washer
Error code Lr
After load and turn on, washer fills partly and seems to try to wash and drain but doesn't. It runs the total minutes set but does nothing and at the end of the cycle error code Lr appears.
    President:
  • 1,304 Answers
Locked rotor you need a new motor control
Posted on Oct 05, 2009
LE error code on my WM1814CW,it fills with water and drains but doesn't turn.
The LE code indicates a motor overload. The washer will not spin to avoid damaging the unit. First unplug the washer and let the motor cool for 30 minutes. When you plug in the washer, check if the unit has been reset.
The error often occurs if you use a non-HE detergent or too much detergent. In that case, do a Rinse and drain steps. Set the Spin Speed to No Spin by pressing that key several times. When that finishes, open the door and remove all of the clothes in the tub. Close the door and set the washer to Rinse and Spin. Run this program several times until you see no suds in the wash tub. If the LE code returns when the washer is empty, check the drain pump and filter for foreign objects. The error can also occur if you wash too many items at once or too heavy a set of items. Try doing a smaller load in the future.
If the error persists, then the tub motor, bearings, motor shaft or wiring may be damaged. Here is the parts diagram and one vendor's list of the replacement parts: http://www.searspartsdirect.com/lg-washer-parts/model-WM1814CW/3204/0153200/K0810333/00002.html . If your washer is under warranty, contact LG.
I hope this helps.
May 25, 2015 | LG Washing Machines
I have a front loading machine(CAH4205AWJ) & it keeps giving me a Lr code.some times it fills with water and drains but never spins.
The LR code means "Locked Rotor". This could be due to:
  1. The control board at the top of the unit has lost connection to the motor and its control board at the bottom. Check for loose connectors. Also try 're-seating' each connector by pulling it off and pushing it on two or three times.
  2. The motor and/or control board at the bottom are shot.
Jun 18, 2014 | Crosley Washing Machines
It said Lr on screen and stops
LR = Locked Rotor on the motor. Many things can cause this. Please contact me, with more details willing to help all I can.
Apr 12, 2014 | Maytag Neptune MAH5500B Front Load Washer
Error codeLr?
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. You don't mention in your question if the LR code occurs every load or once a week.
More information on when the error is occurring would be helpful resolving this problem. Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down. This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes. At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Feb 14, 2012 | Maytag Washing Machines
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag washing machine MAH5500BWW gives me an Lr error message
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source..."Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 (ten being hardest) I'd call it a 3.5. If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job. It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear. Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer. The instructions don't ask you to, but I would remove the brace on the left to make life easier. This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board. My wrench was too big to get to the bolt to remove the harness from the motor. All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor. As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft. The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together. There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish. Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&
Apr 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer wont aggitate.mah5500bwww
Contact Maytag warranty tell them you need a new motor control board it is very easy to replace this unit, this will solve the problem. If your unit is out of warranty insist they send you a new one this is a huge proble for Maytag they'll send you one at no cost just tell them you've been very unhappy and are considering not buying Maytag,whirlpool in the future.
Jun 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Apr 05, 2008 | Washing Machines
Wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Jul 06, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
650 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
