Question about NetGear WGT624 Wireless Router
How do you hook up super-g wireless router - NetGear WGT624 Wireless Router
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 02, 2009
Set password
Download the user guide from here
TRENDnet Support TEW 452BRP 108Mbps Wireless Super Broadband Router
1. Go to Wireless on the management menu.
2. Got to Security on the next menu and change the wireless security from disabled to your choice of security setting and then follow the prompts. Page 31
Apr 19, 2014 | Trendnet 108Mbps Wireless Super G...
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the...
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Dec 31, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
How do i hook up a wireless router to a cable router
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Dec 30, 2010 | Linksys Wireless-G WRT54G Router
With the router hooked up getting on the internet is slow. hooked to cable one direct it's o.k.
Your Wireless speed is all down to the quality of the router and wireless card, and where you are in relation to the router.
Hooking up direct is always going to be faster.
You could experiment with the position of the router in the room.
Check your speeds wired and wireless, use www.speedtest.net.
You could buy a better antenna for the router
Aug 25, 2010 | Linksys WRT160N Wireless Router
Hooking up a wireless router
read this guide:
http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
http://resnet.uci.edu/routersetup.asp
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Mar 20, 2009 | Belkin (F5D7230-4) Router (587009)
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Blitzz super g 108 model bwa711
So I try search with factory thw your wireless new driver for windows vista. Issues you have only 54 g because pc´s has wireless not same 108 super g.
Good luck.
Mar 22, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Blittz suoer g wireless driver?
You can get the driver here, it is the last driver on the page:
Just go through the ads to get it if you dont want to signup to the site:
http://list.driverguide.com/list/company2072/
Mar 04, 2008 | Blitzz Technology BWI715 Super G 802.11g/b...
NetGear Super G 108Mbps Wireless Firewall
If you are connecting wirelessly, then it's more than likely that your wireless card or usb dongle cannot connect as you router is probably set at 108 mbps. Your receivers are more than likely only capable of connecting at 54 mbps so change the streaming rate on your router to 54 mbps. This will not alter your internet connection speed as the 108 mbps only refers to the rate of streaming speed on your local area connection (from one pc to another)
Dec 30, 2006 | NetGear Super G 108Mbps Wireless Firewall...
Unstable connection
This maybe because both peices of hardware are not set at the lower speed of 54mbps as super g is set at 125mbps and can cause problems with streaming. The speed has to be set the same for both, both beind 54mbps. See if this cures it.
Dec 24, 2006 | Blitzz Technology BWI715 Super G 802.11g/b...
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
35 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
