Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Touch screen will not work. Can control recording
Touch screen will not work. Can control recording with the other controls looking through view finder.
  • 125 Answers
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew.
It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty.
Good luck
Posted on Oct 01, 2009
Our screen went blank and we have no radio or any phone connection or rear view camera or any my touch controls. Is there any thing we could look for?
Check for a bad radio/entertainment fuse. Your owners manual will give fuse location and identification. Most of these systems are now controlled by an entertainment module. You can also try disconnecting the battery and reconnecting to see if it will come back online. If not the system will have to be scanned for codes to help isolate the problem. This may be a dealer only repair
May 30, 2015 | 2011 Ford Edge
Sony Handycam DCR-HC32NTSC Play Back
Normally the touch screen should be activated, try removing battery to reset settings, if touch screen still does not work, then it is faulty.
Jul 28, 2008 | Sony Handycam CCD-TRV37 Camcorder
Disable touch screen
    To disable the touch screen feature on your Acer Aspire One model, you can try the steps mentioned below:
    (Note: We recommend that you refer to the user manual of your product before following the steps below)
    1)Click "Start" and then "Control Panel"
    2)In Control Panel, click on the "Pen and Touch" icon
    (Important: If the Control Panel is in Category View, under "View by", click either "Large icons" or "Small icons")
    3)In the Pen and Touch Settings window, click the "Touch" tab
    4)Uncheck the checkbox next to "Use your finger as an input device"
    5)Click "Apply" and then "OK"
    GuruAid.com
Jun 15, 2014 | Acer Aspire One PC Notebook
Touch screen not working
Try this first if it does not work you need a new screen/control panel.
1,. Take a paper clip with machine on and stick it in the tiny hole on the right side of the control panel the screen will change when you see the screen with copiers and computer look under the computer on left side of the screen see a small dot. when it shows press the "3" key go touch panel adjust follow the screen see if that reset the screen if not need a new one.
Feb 07, 2014 | Minolta bizhub 200 Copier
Touch screen do not work when touch on any icon
Your might need touchscreen configuration. Please follow the below solution.
If you are asking about the touchscreen of your desktop PC then I would suggest you go to control panel and look for ELO Control Panel where-in you will be guided to touch three targets on the screen. Then Verify the touchscreen if it is working and aligned properly. If you need to align further then go back to the ELO control panel and repeat the process.
Jul 16, 2011 | Computers & Internet
When I try to view my clips and try to touch the touch screen it does not work.
Did you try if it works with Remote Control that comes with the Camera?, if it works, then the problem is the flexible cable that connects the LCD with the main board.
May 05, 2010 | Sony Handycam DCR-DVD305 DVD Camcorder
The touch screen on my Sony DCR-HC40E is not working
Hi!
The flat LCD cable which goes through the hinges has broken - a common problem with many Sony camcorders. You will have to give it to Sony for repair.
I work for Sony.
Tom
Oct 09, 2009 | Sony Handycam DCR-HC40E Mini DV Digital...
My Sony DCR-HC40E has a fault with the touch screen. The touch screen is not displayed so I am unable to play/edit or even record/view anything. The screen is usable if you know where the controls are...
Hi!
I work for Sony.
Tom
Command mode
I did the same thing and lost all remote control to the recorder. Try holding ENTER & 3 in unison for as long as it takes (30 secs or more ) to view change on TV screen. This should get u back to system menu where u can change back to dvd 3 (default ) If doesn't work get a one for all remote and enter code 0533 which will get u in to the recorder command lines. PS enter & 3 worked 4 me.
Oct 22, 2008 | Sony RDR-GX300 DVD Recorder
Remote control will not work?
Hi Quad, recently I also got same recorder and faced the same problem with the remote controller. today i tried to solve this. i opened it up. it turned out the battery connections are not proper. The battery connection are in the form of a spring coil which touches the outerside of the battery which is not touching properly. I bent and slight lift it with a plier and it started working. The other connection is touching front side of the battery(on backside you see label cr2025 printed) and this is alright. I hope it works for you too. with best regards
Nov 26, 2006 | Cyberhome DVR 1600 DVD Recorder
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
272 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
