Question about Dryers
Dryer will not start. May have overheated due to clogged hose vent
    Problem Solver:
  • 6 Answers
Check to see if you have a breaker built into the dryer and reset, and that your breaker panel of your house has no tripped breaker. Check that your door switch is making contact with the door/striker on the door. You should hear a distinct "click" when depressing it with your finger or end of pencil eraser. These switches are notorious for breaking or bending, and if you have children that like to ride the dryer door they can bend the door out of alignment. You can UNPLUG the dryer, remove the switch, and use a multi meter on the two wires to make sure you have good continuity when the switch is depressed, depending on how handy you are.
-JMFT
Posted on Oct 01, 2009
My samsung dryer turns off after about 4 min
Sis it overheating due to a clogged vent hose? Remove the hose at the wall or floor and at the dryer. Look into it if it's clear and clean hook it back to the dryer only and run the dryer with it just venting into the room (if it's dirty take it outside and use a blower to clean it) if it runs with the wall or floor side unhooked you may have a clog in the wall or floor run (you may not have a long run as I do mine is 30 feet) good luck if this doesn't work check with mfg website for FAQ.
Kevin
Aug 06, 2014 | Dryers
Kenmore dryer lights up but will not start just gives a beeping sound
Most likely a blown thermal fuse due to a clogged vent system, inside the machine and/or the vent hose to the wall port.
Clean the vent system and check the fuse, replace if needed.
Mar 08, 2014 | Kenmore Dryers
Heating problem
There is a thermal cutoff built into the dryer to protect from fires due to overheating. This could be activating after the dryer starts running for a while. Is it possible that the exhaust duct is clogged up with lint? Check the airflow at the dryer vent.
Dec 17, 2013 | GE DCVH515GF Gas Dryer
I have a kenmore elite dryer mod c60952990 / ser mk0501696. it keeps shutting off after only about ten min. if you set the timer to 90min it still turns off after about ten min. same if you use the ''auto...
It sounds like it might be overheating. Could your vent be clogged up? When you start the dryer go outside to the vent to see if there is a real good flow of air coming out. If not, the hose or the insides of the dryer are clogged, or the hose is kinked. Sorry, I can't come up with anything else that would be an easy fix. Best of luck.
Jul 26, 2010 | Kenmore Dryers
Whirlpool gas dryer LGR6636PWO heats for appro. 5 minutes & quits heating but still runs.
First check the exhaust vent and connecting vent material for a clog. If vent is OK,replace the gas valve coils.
Oct 04, 2009 | Whirlpool LGR6636 Gas Dryer
Dryer went off for overheating won't start again . Reset is ok next to the burner.no point to point diagram , sequence of operations , or component i.d. beautiful machine.........
HI, if this has occurred, the issue may be a faulty high limit thermostat or, the thermal fuse has been tripped, due to an obstructed ventilation system(exhaust assembly).
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
NOTE***
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
Jul 09, 2009 | Bosch Dryers
Clothes Dryer Break Down
Check your dryer vent and lint collection area for clogs, make sure there is no kinks in the dryer hose and the one way vent outside your house is not blocked. Your dryer is overheating and shutting down due to a thermal fuse that is on a timer and takes while to reset.
Mar 11, 2009 | Frigidaire Dryers
How can I connect my dryer to the vent without crimping the hose? Whenever I connect the hose and push the dryer to the wall, the hose gets holes in it...
The dryer should not be pushed all the way against the wall. For the ventilation to properly work, you should leave about a one foot space between the back of the dryer and the wall. Using 90 degree elbows on the dryer and wall can also eliminate crimping. Also, it is strongly recommended that use use the semi-rigid metal type vent hose ducting. It is not that expensive and comes in adjustable lengths. The semi-rigid ducting is recommended by most builders and it resists crimping and rodent damage. If you continue to use a dryer with the exhaust vent clogged it will lead to eventual heating circuit failure due to overheating. If you have any questions, please post back and let me know. I hope this helps answer some of your questions.
NOTE: If you purchase semi-rigid ducting, make sure you purchased the hose clamps that go with it. This will prevent the hose from slipping off the connection points.
Jun 15, 2008 | Dryers
Wont start up.
Sounds like the motor is failing. The main cause of failure is overheating due to clooged venting. Is the dryer taking more than 60 mins to dry?? If so then the vent is clogged. Its likely too that the motor is covered with lint and not being able to properly dissipate its own heat, you could clean it and see if it helps but usually once they are shutting down overheated (the burning smell is the motors' internal windings being very hot) they need replacement.
Nov 19, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
