Question about Pioneer VSX-515 Receiver
The unit wont power up it is stopped at the first power relay. iT SEEMS THE POWER RELAY IS BAD. cAN IT BE FIXED
    Novelist:
  • 133 Answers
If the power relay clicks, this means that the coil is good but the relay contacts may be dirty (contacts need to be cleaned or the relay replaced).
If the relay does not click, then it might be a bad fuse, a bad relay coil or a faulty relay drive circuitry, no power to the relay drive circuit, possibly an internal overload or a short somewhere in the unit which causes the unit to stay off to protect itself from further damage that might occur if it had turned on.
regards
Triarcuate
Posted on Oct 01, 2009
Testimonial: "thank you that what i needed to know"
How to determine if Protector O/L relay is bad and how to "reset the unit".
The relay is used to take the start capacitor and start winding out of the circuit once the compressor has come up to speed. Using an ohm meter, no power to the unit, and relay disconnected, you can determine if the relay contacts are open or closed. With no power to the unit, the contacts should be closed. If they are open, the relay is bad. However, the start capacitor could be the problem.
Oct 02, 2014 | Samsung RFG297AARS Bottom Freezer French...
What's your problem?sony v444es 5,1 wont turn on, only clicks the relay on power board non stop
Sounds like your power transformer is bad. You might also check the power board for cracks. This model had a history of that.
Jun 21, 2012 | Sony STR-V444ES Receiver
92 accord runs rough at a stop and sometimes wont start right away after driving for awhile
Have your main power relay replaced as your problem is the typical symptom of a bad main relay, when it gets hot after driving and trying to restart. The running rough problem might be your center engine mount. Have it checked to see if it's bad.
Oct 19, 2010 | 1992 Honda Accord
06 vue cooling fan wont shut off tried new relay swich and the 40a fuse is obviously good. what could it be, temp sending unit?
The power for the fan comes from 2 relays in the
junction block on the left fender. One is a high fan relay 40amp the other is the low fan relay 20amp.
If either one is stuck, it will power the fan. Also if the
engine coolant temp(ect)sensor is bad, it can send a
false signal to the engine control module(ecm) and powering the fan. With the engine cool, if the fans still
running. Unplug the ect sensor(on thermo. housing)
if the fan stops replace the sensor. If not pull the relays one at a time. And see which one stops the fan. If none of this works it may be an ecm problem.
Hope this helps.
Mar 21, 2010 | 2005 Saturn VUE
The Horn wont stop beeping so I took the fuse out now my battery dying every morning.
Most vehicles have relays to run different things and in most cases the relay gets power before the fuse so if you pulled the fuse the relay is more than likely still getting power. It may be that you just have a bad relay. You can also find the horn itself and simply un plug the power supply wire going to it.
Feb 06, 2010 | 2007 Jeep Commander Rocky Mountain
My blower motor for my 1993 dodge dakoto w/3.9 v6 has stopped working,my fuses are good,but nut getting power to the power plug
Then you are possibly have a bad relay or a bad switch. Check the relay under the hood and make sure it is good. If the relay seems to be good replace the switch on the dash.
Oct 06, 2009 | 1993 Dodge Dakota
Hi, just replaced the capacitor thinking that would solve the problem but it appears it did not. The motor outside would kick on the unit inside would kick on but the blower motor inside works sometimes...
Turn off the power to the air handler(indoor unit). Remove the access panel. From the motor,trace the wires back to the fan relay. One wire will probably trace back to the incoming power terminal. The other is the fan relay. It could be intermittent thermostat signal to the relay or a bad relay.
To verify if the fan motor is good,you can remove the one wire from the relay and re-attach it to the other side of the incoming power terminal. If it runs OK there,replace the relay. If it does not run,replace the blower motor.
Sep 28, 2009 | Heating & Cooling
Roof a/c unit clicks when wall thermostat is adjusted but wont come on?
no ac power you are hearing a 12 volt relay tellling it to come on but there is either no ac power or control ac relay is bad and you will have to replace control unit to ac useually arond 150 depening on unit
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
Fuel problem on my 1998 Camaro
Check for a bad connection to relay. relays shouldnt just go bad after you keep replacing them seems like it would be a bad connection for the relay and when you replace it you move the connection in the fuse panel. find wireing scehmatic just jump the power for the fuel pump directly to power and see if it works if so examine that you have power from the ignition switch and a ground to energize relay and that power is good on feed side of relay.
Oct 14, 2008 | 1998 Chevrolet Camaro
Pioneer VSX-515 Receiver Logo
774 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
