Question about Kyocera KM-1505 Copier
KM 1505 copier machine
I have error code C 710 in one machine and A 400 in other machine how to solve the problem? I have no service mannual for the same machine. I have AMC for the same.
Shailesh Shah. India.
  • 3 more comments
  • Rathod Dec 20, 2007
    Recently I have C 610 code problem in KM 1505 copier machine let me know the solution for the same.
    Shailesh Shah
  • R Rohan Dec 30, 2007
    All the components are found OK. The error code is to be reset. I don't know how to reset the error code.Please inform the same.
    Thanks,
    shailesh shah, India.
  • Anonymous Feb 14, 2008
    1. c610
  • Rathod Mar 25, 2008
    I have C 610 & C620 error code. I have checked Thermister, Thermostate, Heater Lamp with wire & its connector all are found OK. Then I checked Voltages on Power supply PCB where I found there is problem in CN 1 pin no 9 i.e. FH on/off, input I am getting voltage 11V instead of 0/5 volt DC. For that I need cercuit diagram of Main PCB as well as Power PCB to rectify the fault. I have no diagram. If you have any suggetion or diagram kindly send me via mail. My mail address is shaileshbshah@aol.com Thanks. I am shailesh shah from Gujarat, India.
  • Anonymous Jul 31, 2008
    i have abroblem the copier rwite C 620
Click cancel+start+light then release all then press cancel.... you are now in simulation control service..... press the zoom in and out so that it will display 163.... after displaying 163 press start... the machine will restart then the code will lost.. if it return there is machine problem somewhere in the fusing unit....
Posted on Apr 25, 2008
    Problem Solver:
  • 6 Answers
You can run U163 simulation to reset the fixing error code of 610 or 620 Unfortionatly the service manual dosen't go into much detail about the circutry.
Posted on Apr 03, 2008
    Sniper:
  • 54 Answers
A C710 is a toner sensor problem. usually need to replace the developer or toner cartridge.
A C610 code means the fuser has a open circuit, usually a open thermostat. Some of these are resettable by either smacking the thermostat on a hard surface, or pushing a button attached to it. Most kyocera's don't have a button on them. It could also be a broken lamp in the fuser.
Please don;t forget to rate your answers.
Posted on Dec 21, 2007
What happen when kyocera KM-1505 is bringing error code J98
There's probably a time piece of paper or something blocking a sensor or pressing down on an actuator or something
try checking this then do a good clean of the unit.
Jan 16, 2015 | Kyocera Mita Km 1810 1510 1505 Copier Drum...
Code c6020 180
That is a fuser error. Replace the fuser & reset the code in service mode. You will also want to update the firmware of the machine.
Dec 13, 2013 | Kyocera KM-1505 Copier
Ok i have a copy machine is Kyocera km 1505 is appear code Ap i put new toner and is the same what can i do
try to put direct toner in the developing unit then restart the machine if problem still persist try to replaced your developer
Apr 11, 2011 | Kyocera KM-1505 Copier
How to solve error c6020 for Kyocera KM-2035 copier? it has stopped
The C6020 is a fuser error code and should be checked out by a Kyocera tech.
May 18, 2010 | Kyocera KM-1505 Copier
Error C-0150 back up memory of kyocera KM-3540
http://www.eserviceinfo.com/downloadsm/15534/kyocera_km1620/2020.html
http://www.fixdevice.com/smanuals/file/34223.html
Repair manual above.
http://www.fixdevice.com/smanuals/file/34229.html
You mention two, KM-1505 & KM-3540 here is the generic manuals for both.
www.feedroller.com/Store/Service%20Manual/KM_1505P.PDF
Service manual above this is the fix manual above.
Backup memory read/write problem
(engine PCB)
• Read and write data does not match. Defective engine
PCB.
You have a bad board in the printer it must be replaced.
Apr 08, 2010 | Kyocera KM-1505 Copier
I am Having Problem with Kyocera KM 1635 with code C-6 what that mean and how we can solve that
you have a problem in the fuser/fixing section. error code should be 4 digits long to correctly identify the problem
Aug 27, 2009 | Kyocera KM-1505 Copier
What is C 710 error codes?
You machine toner is empty insert toner
Jun 14, 2009 | Kyocera KM-1505 Copier
Kyocera Mita KM 1505 copier machine
Hello Sir,
I would like to ask you that I have a kyocera mita copier KM1505 and displays the code error like C610,So try to help me in order to resolve or fixe that problem.
Thanks
Pascal NIYONSENGA
Rwanda-KIGALI
Apr 03, 2008 | Office Equipment & Supplies
Km-1505
THE MACHINE DISPLAY CODE J98
Oct 26, 2007 | Kyocera KM-1505 Copier
Kyocera KM-1505 Copier Logo
477 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
