Question about Kitchen Ranges
General Electric P7 Automatic Cleaning
How do I use the General Electric P7 automatic oven cleaning function? I can't find the Model number but I think it's was purchased in 1974 - 1977.
  • 1 more comment
  • asturcke Oct 01, 2009
    STANDALONE RANGE
  • monster_tech May 11, 2010
    Is this a wall oven (built-in) or stand alone range???
  • achaver921
    achaver921 Oct 29, 2012
    built in wall it's missing a oven rack, would like to purchase one
    Problem Solver:
  • 7 Answers
Simple....Press the lock button and slide the arm over to lock door.
Set the stop time and turn t-stat to clean and selector to clean and it should start cleaning.
Never set unit to clean while you are gone,just in case there is a issue with your oven..
Posted on Oct 01, 2009
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
Nov 08, 2014 | General Electric GE 24" Single...
Are the oven shelf/racks to be removed before the automatic cleaning process begins?
Normally it is not necessary. The racks will be cleaned as well. Do you have the manual for your oven? You should take a look in your manual for instructions for the cleaning cycle, if you suspect that there is something different about your oven. If you do not have the manual ,you may be able to download one here at http://frigidaire.com . You will need the model name and number of our range.
Thank you for using FixYa.
Dec 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    Can't get the GE P7 door lock engaged in order to
    have to have a repairman come out and reset the code on the inbord computer not a simple fix i know i sell appliances
    May 17, 2010 | GE 30" Built-In Single Electric Wall Oven...
    Can not work automatic clean cycle on Maytag range
    Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
    May 05, 2010 | Maytag MER5775Q Electric Kitchen Range
    The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
    Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
    Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
    Self Cleaning Oven help
    It should run with you setting anything but clean. You can obtain a copy of the owners manual from the maytag site or by googling your maytag appliance model number.
    Dec 24, 2008 | Maytag 24" Built-In Single Electric Wall...
    Whirlpool Electric Range - Setting Timer Stove says door
    It may be that the door interlock is faulty.
    It will not turn on if it thinks the door is open. It will probably work fine if in manual mode - as this is not used.
    If out of warranty, check the door interlock for anything broken off, and with a meter to ensure correct operation.
    If this is ok, check cabling back to controller. This board may need repair/ replacement if faulty.
    Jun 11, 2008 | Whirlpool RF378LXKS Electric Kitchen Range
    Kitchen Ranges Logo
    916 people viewed this question
    Top Kitchen Ranges Experts
    Oloyede Monsuru
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
