Question about Bosch Axxis WFL 2060 Front Load Washer
I keep getting e-13 error message. Can you help? Machine won't spin out and has water in the bottom when I open the door.
  • Bosch Master
  • 2,605 Answers
I know a fault code e-13 indicates a flow rate was measured to be inadequate. I'd suggest pulling off your water inlet hose (turn the water off first of course) and checking for dirt or other obstructions affecting the flow into the machine. That is the most common issue, especially in rural areas with well water, or areas of very hard water.
Aside from that being the problem, you'll need to **first pull the plug to the unit from the wall outlet/or dryer,** pull the sensor (located downstream of the inlet valve, before dispenser assembly, if removing it, make a note of the direction. the body of the sensor will have a small arrow indicating the "flow direction". make sure to reinstall it the right way.) then check for dirt/foreign particals in that and either clean it or replace it, or the inlet valve assembly itself is bad. (you can ohm it out at each coil and should have a value of between ~2.7 - 4.5k ohms).
hope that helps, let me know by giving feedback.
good luck
Posted on Oct 02, 2009
Won't drain the water anymore
Drain motor is usually located on the bottom of the machine. Hopefully you have an access panel separate from the main door panel. Should be a hose coming in and a hose going out. Put the machine in spin cycle and see if you can feel the pump spinning. If the pump is very hot, chances are something is blocking it. They will usually have an access port that can be opened up just for this reason, be ready to catch the water when you open it up, and please turn the machine off first. If you get no sign of life from your pump it may have died. Also check for any blockages in the drain lines. All of this should be easily accomplished with a couple screwdrivers and towels
Apr 10, 2013 | Baumatic BTWM4 Front Load Washer
Tub will not drain water
Open the small door at the bottom of the machine, left. pull plug from hose, it will drain about a cup of water. Then unscrew the filter and clean debris.
Sep 03, 2012 | LG WM-0532HW Front Load Washer
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
My bosch washing machine model WFVC6450Uc/19 FD 9002/901476 has E:13 flashing. i was able to drain the water manually but now the door locked there is beeping sound when i try to start it. how to fix it
Hello & Welcome to FixYa
E13 error in your Bosch WFVC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Washing Machines
Help! My front loader "duet"
Hello, welcome to FixYa.
Based on your description specifically the door not unlocking combined with the unit not spinning adequately or as you stated "having trouble with getting spin cycle to spin out water" I'd suggest you check the pump filter and sub-components, i.e. back flow ball, drain hose etc.
Here's a link to my solution or explaination to guide you through checking these things. Typically this is associated with an error of F2, F21, or "suds" but not always.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
As for unlocking the door, it's a good idea to get the water out first, but in any event to do so is as follows...
Once you remove the service panel at the bottom (as shown in my "repair tip") there is a manual latch release just below the lock latch assembly that you may be able to see visually or feel for by reaching up to the latch and pull the small "loop" below the lock...this is a image of what you'll be looking for.
Let me know how you make out or if anything is not clear and I'll try to help you moving forward in any manner I can. Good luck.
Please take a moment to rate the info and provide a testimony on my assistance and your experience here at FixYa.
Regards,
Macmarkus :)
Jul 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Apr 10, 2010 | Washing Machines
Machine will run through entire cycle and will not spin. It quits at the spin cycle. I checked the Black boot at the bottom. Removed and cleared out coins. Checked pump- it was turning freely. Reinstalled...
I had a similar problem and found out the "latch" on the washer door broke off. The machine won't run in spin cycle if the door is"open", but it would run through the wash cycle.
Feb 05, 2010 | Frigidaire Washing Machines
My samsung 7kg front loader keeps flashing UE on the error code (spin cycle) and I can't open the door
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 26, 2009 | Samsung WF337AA Front Load Washer
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Odd messages appearing on lcd screen and not collecting water
What make and model is your washer?
Cannot help without further details
Nov 19, 2008 | Hotpoint Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
85 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
