Question about Tag Heuer Kirium (CL1212.BA0705) Wristwatch
Aquaswiss trax watch
How do you adjust the time and the other features?
  • 1 more comment
  • risx Dec 25, 2007
    how do you adjust the band on a aquaswiss trax watch?
  • Anonymous Mar 19, 2014
    how do I change the battery Aquaswiss G74 watch
  • Anonymous Mar 26, 2014
    adjust time
  • 5 Answers
AQUASWISS TRAX MODEL:
For clarity:
There are three adjustment knobs on the right side of the watch. Two are smaller than the main time adjustment knob. For clarification I will label:
Top knob: #1
Middle knob: #2
Bottom knob: #3
To adjust the stopwatch feature:
1. Turn #2 counter-clockwise until it pops out to its adjusting position.
2. Pull #2 towards the right until you feel the first click. (There are two click positions).
3. Simultaneously hold both #1 and #3 down until you see the 1/16 hand and the 30 minute hand rotate automatically to a fixed position.
Now you are ready to calibrate the stopwatch feature.
4. Click mulitiple times on #3 and you will see the 30 min. had move clock wise incrementally with every click. Keep clicking on #3 until the 30 min. hand reaches its apex (to its 12:00 position).
5. Now click multiple times on #1 and you will see the 1/16th hand move in very small increments clockwise. You may be bold and try to hold down #1 and let it swing as close as possible to the 12:00 position and then multiple click #1 to get it precisely to its apex.
You are almost done.
6. Now simultaneously hold #1 and #3 until you see both the 1/16th second hand and the 30 minute hands auto-rotate clockwise to their respective 12:00 positions.
Fantastic! However, now you have to return the watch back to its original locked position. This is where it could get a little tricky.
7. Make sure the time is correct. Using #2 fully extended to its 2nd click position you may adjust the time.
8. Using #2 extended to its 1st click position you may adjust the date. (Here's the trick, do not set the date for today's date. Rather, set it for the day before or in some cases, 2 days before. I will explain in a moment).
9. Now, depress #2 fully back towards the main body of the watch as best as possible and while holding down #2 turn it clockwise until it locks into position.
During this operation you may notice that the date will go forward until the watch locks into position, ergo, I had to make sure the date was for the day before...and it some cases, 2 days before.
Your watch is ready to use.
The stopwatch feature for this analog watch works very similarly to that of an actual stopwatch.
Press and hold #1 once to stop the 1/16 hand. Press and hold #3 to have both the 1/16th second hand and the 30 minute hands return to their 12:00 positions. Now you are ready to race!
Press #1 to start the stopwatch. Press #1 to stop the stopwatch. Press #3 to return the hands back to their respective positions. You may even press #3 after you press #1 to get a second reading but I will let you figure that out for yourself.
Hope this was helpful!
vsndesigns
http://www.rgmarchitect.com
Posted on Jan 25, 2008
I went to http://www.aquaswisswatch.com/Scripts/prodView.asp?idproduct=2642&IDCategory=101 and clicked on the "contact us" link, asked them for a copy of the owner's manual and received one within a couple of hours.
Posted on May 21, 2009
Need advice how to change time on tag kirium
Posted on Apr 11, 2009
3 Suggested Answers
vsndesigns
  • 5 Answers
SOURCE: how to adjust the band on a aquaswiss trax watch
Warning: This is if you don't have any professional watch tools. And I definitely recommend you taking it to a jeweler first.
That being said...
I was able to adjust my band by using a small nail and a pair of needle nose pliers...and Krazy Glue or Super Glue (last warning...you really should take it to pro)...
1. Push the any one of the pins that holds the wristband together until you see it protrude from the other side. While applying pressure to the pin, quickly grab it from the protruding side with the needle nose pliers and pull off the metal cap from the pin.
2. Note you will notice that the pins are actually 2 pieces! They are not screwed together and it makes for a pretty poor design since, one the pins are taken out and then replaced after taking out the appropriate links... they tend to get loose and you will lose that tiny metal cap that holds the pin in place.
3. A professional will have a clamp that is small enough to press these two pieces together. But even that is precarious. I strongly recommend that you carefully apply a drop of crazy glue on each end of the pin, after you are finished.
Final note: I was luck to have spare pins from the links I removed to replace the pin that worked out of its cap. That little sucker is lost to the watch gods. Have fun! Also... you can make final adjustments at the 3 pin location at the wristband release.
vsndesigns
vsndesigns
  • 5 Answers
SOURCE: Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
Posted on Feb 09, 2008
How can I tell my watch is a genuine aquaswiss
take it to a watch shop and see if they can tell you.
Dec 23, 2016 | Watches
How do I change time on my aquaswiss swiss sport 24 watch
I looked this up and find many images many have only a winding stem and many had it and 2 buttons . there fore it is tough to guess which you have to even suggest how .post you exact photo and then perhaps we can assist you
Nov 26, 2015 | Swiss Watches
Just got myself the new SWISSport M but it not moving
Your watch is a battery powered watch. If it is not running, the first thing to check would be the battery. To turn it on just push the crown in.
Oct 07, 2012 | Aqua Swiss Aquaswiss Trax Wrist Sharp...
My dog ate the band on my aquaswiss swissport purple watch. where can io order a new one?????
You can call Tag Heuer and order a new band or you can try online sources such as ebay who sometimes sell them at a lower price.
Oct 19, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
How do I set the DAY (not the date) on an Aquaswiss watch? The day is displayed in a separate dial at the 6 O'Clock position on the watch face. The manual does not indicate how to set the DAY. The movement...
Their web site is pretty useless as far as instructions go (as you may have already found) but looking at their range, it looks like your is a "Trax" model.
As a guess, I suggest that you pull out the crown wheel (it may need rotating anticlockwise about a 1/4 of a turn) and pull is out.
I would expect their to be two "out" positions, the second one usually operates the hands and the date, so this leaves only the first position to be available to adjust the date.
Experiment a little to find the function you need!
Sep 18, 2010 | Watches
Looking for an instructional booklet for my aquaswiss sport watch
Thank you for contacting FixYa.<br /> Very difficult to find certain odd brands such as Aquaswiss. You wil have to contact them direct at :<br /> <a href="http://www.aquaswisswatch.com/Scripts/contactUs.asp">http://www.aquaswisswatch.com/Scripts/contactUs.asp</a><br /> <br /> Best regards,
Aug 25, 2010 | Bulova Watch
How do I get a steal band for my Aquaswiss Trex watch?
look for a tag store near by. if u cant find one most jewelry stores with a shop (not in a mall) can either do it there or send it out. sometime the band can be fixed
Oct 07, 2009 | Tag Heuer Kirium (CL1212.BA0705)...
VSNDESIGNS SAYS:
Feb 09, 2008 | Watches
How to adjust the band on a aquaswiss trax watch
That being said...
vsndesigns
Dec 25, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
Tag Heuer Kirium (CL1212.BA0705) Wristwatch Logo
2,733 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
