I have an unidentified wire that's seemingly out of place. I do not know what it does temp sensor maybe.
    President:
  • 1,187 Answers
The wire is a thermocouple wire sensor.
Look closely, (it is safe to touch).
It loooks like a bare copper wire. It is actually two wires (thermo "couple"). A tiny electrical charge will flow from one of the metals to the other when heated... that makes is a good way to measure heat (or coolness). Works just like a thermometer.
It needs to be placed in the return air duct or condenser so that the thermostat can be triggered when the coolness setting is reached.
Posted on Oct 01, 2009
Sensors for cooling
Sensors for cooling what? If you mean temp sensors, should be two. One will be for dash display (usually has only one wire) other is sensor for computer to know engine temp (usually has two wires). Both should be located near the place where the top radiator hose connects to the engine, and near thermostat. If we really knew what your issue is it would be helpful.
May 15, 2014 | 1998 Mercury Grand Marquis
Temp gauge stuck
Maybe temp sensor became disconnected, or damaged.
Look for it in the engine block, right by the radiator hose intake. Test the gauge by shorting the wires that lead up to sensor. If gauge reads full temp, gauge and wiring is ok. Next clean the contacts at the sensor, and if not successful, replace the sensor.
Feb 03, 2010 | 2004 Hyundai Elantra
84 Goldwing over heats even at an idle. The fans don't seem to be engaging.
The problem could be the water temp sensor that switches on the fan. It is normally located in the radiator and has one wire going to it. Earth the wire out to the frame, if the fans come on the sensor is the problem, if it does not the fault is in the fan unit, wiring or maybe the fuse.
Jan 30, 2010 | 1983 Honda GL 1100 Innerstate Gold Wing
Silverado Coolant not getting hot enough?
it has to be either a broken gauge, faulty wiring, or poor coolant flow (although in the summer i doubt the coolant is staying 'too cold' in reality).
First, we will check the temp sensor 1. Pull the temp sensor out and let it hang. 2. Boil water -- it will be at 212* at its boiling point but cooling rapidly, so speed is key. Or better yet, if you have a thermometer and vegetable oil and steady hands, heat that up to 250* 3. Take the water or oil to the sensor and pop the sensor in it. Watch the gauge to see if it reads accurately (should show around 200 if you moved quickly with the water, oil will still be ~240ish and will work better, but is more dangerous). If the gauge is off, then we've found the problem. For better measure, if you have a thermometer you can place that next to the temp sensor to compare results.
if the temp reading is too low (lower than what your thermometer reads), it is also possible that you have a short in the wiring or simply corroded wires connected to it, adding resistance to the wire which would result in a lower reading. (people sometimes use this to their advantage with the air temp sensor -- add a 100ohm or so resistor in-line with the sensor to trick the cpu into thinking the temp is colder, prompting it to adjust the air/gas mix and yielding a couple hp increase, although damaging to your system.)
the more i think about it, the more a faulty wiring feels like it could be the problem. if the temperature is reading accurately, i'd take a serious look at the flow of coolant through the system. if it isn't heating up then it must not be contacting enough heat. there may be blockage somewhere; crimped hose or maybe just mystery gunk.
hopefully this helps, if anything it's a start. most of the time it seems like solutions are found unexpectedly when testing completely different things. good luck!
Jul 14, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Temperature guage inside car
sounds as thought the location of the temp sensor is not very good. If you had a way to trace the sensor, you could find out. If its too cold, someone has placed it in the wind, or in front of the car. If its reading too hot, its sitting too clos the the radiator/engine/or exhaust. If you have had any body work done to the car, or major work in general, someone probably moved it. Or maybe the person before you had work done to it. (if its used). And I guess the sensor could be broken, but in that case, they usually read one temp, or read error.
Feb 13, 2009 | 1999 Volkswagen Passat
Gauge temperature
Your description of the problem is not very clear. It seems as if your temp gauge does not work, or does not indicate the correct temperature.
If you disconnect the wire from the sensor unit and put it to battery negative (ground), the gauge should move to the full hot position. If this does not happen the best chance is that the gauge does not work. If it does work, the sensor is faulty. In a very unlikely situation, the wire could be faulty..
Aug 29, 2017 | 1999 BMW 318 ti
Over heating
In general I know of no reason per se to replace the thermostat and temp sensor because you replaced the radiator fan. If the temp gauge seems to be staying in the 1/3-2/3 of full scale, and there is no apparent engine control issues as the engine warms from cold to operating temperature then there is no obvious reason to replace those items. Other than fan motor failure is there any reason for you to believe these other parts are at fault?You can get a free fault code readout at an Autozone parts store which would highlight a temp sensor problem, but there is no fault code for the thermostat except maybe the one for engine running cold for too long a time after start up. You could also check the resistance of the temp sensor which should run around 10-14,000 ohms when cold and drop to 700-1,000 ohms when warmed up.
I don't know about the issue of replacing the thermostat because I don't know which engine you are working with. So let me know an
Jul 12, 2008 | 2002 Chrysler PT Cruiser
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
