Question about Allegro DVD Recorder VCR Combo ABR521
Dvd player does not read dvd
Dvd player does not read the dvd and when it ejects the dvd it comes out spinning, you can see the word reading but that's all
    Novelist:
  • 133 Answers
Suggests that the motor regulator IC has problems spinning the disk in a normal way so it will overheat and start to behave in an erratic way - consequentially it may have problems stopping the disk before it ejects.
However, this does not necessarily mean that the IC is bad (far from it), it is just overheating and will usually do so when the spindle motor has oxydized brush contacts - this means that the motor resistance is now higher and that it will not spin at a correct speed with the voltage supplied from the IC.
The electronics will then try to compensate for the speed, but the IC may overheat and start messing up.
Cleaning or replacing the spindle motor might solve the problem, but if the motor can not be replaced because of the unit design and buildup, then this usually calls for the replacement of the entire disk mechanism.
Anyway, this is just one of the possible causes, you might want to try cleaning the laser pickup lens first, but i'm not sure if doing so will make things any better.
regards
Triarcuate
Posted on Oct 01, 2009
  • zbuilder801 Sep 05, 2015
    Wrong wrong wrong. These motors are brushless. Stop giving false information.
    President:
  • 1,768 Answers
This could be due to the speed the DVD was duplicated. or the optical reader may have proper voltage and has stopped reading. this is a power supply issue. The board needs repair.
Posted on May 25, 2010
3 Suggested Answers
silly girl
  • 513 Answers
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Posted on Jan 30, 2006
SOURCE: dvd player wont eject or load..........
http://www.fixya.com/support/t208832-lite_lvc_9016g_dvd_drawer_not_open
Posted on May 22, 2008
Won't read Dvd/Cd as loaded
It is a problem of the optical head being covered up by foreign particles obscuring the optical lens. Try using a CD/DVD cleaner disc which has double brushes and one add some solvent which comes along with the pack.Simply play it & keep ejecting and inserting the disc makes the disc to spin, till your player starts reading it..............................sodeep
Oct 06, 2009 | Coby DVD-224 Player
Dvd in in player and won't eject. screen reads "loading".
Try unplugging the unit and plugging it back in after a couple of minutes, if cd still won't come out you can unplug the unit and manually remove the cd by taking the outer casing off.
Sep 07, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
DVD will not eject
Power off the unit, if it will not power off, unplug the unit for a few minutes, then plug back in.
press the power button (turning it on). Before it can attempt to read the disc, eject it.
Feb 16, 2009 | JVC HR-XVC27U DVD Player/VCR
DVD player will not read any disc
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VER YCAREFULLY NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knacked and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Jun 17, 2008 | Panasonic DVD-RV31 DVD Player
No eject/reads hello thats all
Is there a small hole under the tray? Use a straightened paper clip and piu it in there and push, it should manually push the tray out. If there is anything on the DVD that looks like a computer program, the DVD may be trying to read it as a BIOS upgrade. The spindle motor may be bad too as the DVD is waiting for the platter to spin up to read it and is timing out.
Mar 03, 2008 | iLO DVDR04
The dvd player will not eject the dvd
We once had 2 DVDs in the tray (thanks, kids). The tray would not open and had similar symptoms.
We eventually pulled/pried-open the tray (while it was attempting to open by itself, aka you could hear the try motor was activating.)
I'm sure a tech would cringe at this, but it did eventually pop open (with our aggressive help) - and all is well.
Good luck.
Jan 05, 2008 | GoVideo Go Video DVD/VCR Combo
Can't get a disk to play
I've seen failure of the spindle motor to cause problems like this. Problem can also be a leaky diode in the power supply.
Nov 19, 2007 | Panasonic DVD-S35 DVD Player
DVD just says reading.....
Too high speed when writing discs. Use no more than 8X. Try 4X. Also, read again the user manual and check the kind of MP3 files this device can read.
Sep 13, 2007 | JVC KD-AVX1 Car DVD Player
Televison & Video Logo
253 people viewed this question
Top Allegro Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Repairing
Computer Repairing
ray gallant
Are you an Allegro Televison and Video Expert? Answer questions, earn points and help others
