Question about Canon PIXMA iP4200 InkJet Photo Printer
I have a ip4200 paper jam error - there is no paper jam
Paper jam will not clear when first power up the printer sends a piece of paper through the printer and then paper jam light flashes 3 times again and again
Try spraying the printer out with a can of airdust
Posted on Dec 21, 2007
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Error number 6A00 for Canon Pixma IP4200 Blinking Power and resume light.
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printer feeds through blank piece of A4 fast, followed by another one, slowly
Service error 6A00 Cancel printing and turn the printer off and then back on.
If this doesn’t clear the error, see the printer manual for more detail.
Jun 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error Light does not turn off!
Hi, it sounds like your printer experiencing a hardware failure thats why the error light still on. The sensor that detects paper jam or any obstruction might be defective. Aside from that your printer may also experienced a motion carriage error. You can to power cycle the printer & check ink cartridge. if the error still present your printer might be needed to be send to the nearest Epson Service center.
Tirzo
Mar 31, 2008 | Epson Stylus CX4800 All-In-One InkJet...
No printing
If you are sure there is no paper jam,have you tried reseting the printer?
  • unplug the power cord for the printer.
  • press and hold the power button
  • plug the power cord in still holding down the power button
  • the power light should come on when it does release the power button
  • power on the printer like you normally do
hope this helps good luck
Nov 28, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
I had a paper jam in my ip4200.
Make sure the paper ways are clear of bits of paper- a vacuum cleaner hose? Also look in on www.fixyourtownprinter.com
Jun 01, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
199 people viewed this question
old marine
old marine
