Question about Kenmore Dryers
The drier doesn't work - Kenmore Dryers
  • 80 Answers
Check your power and make sure your breaker is'nt tripped.
Verify you have 220 volts at the plug.
Posted on Oct 01, 2009
ZWD 1662 W start/Pause button flashing but not connecting to programme
hi,if this is the washer drier type try this,unplug m/c!! take lid off and locate the four connections to the drier unit near the back panel.some connections will be double tagged others single tag.disconnect all four connections and let wires dangle down a bit ,they shouldn`t touch anything.plug m/c back in and try a program such as drain and spin,and then if ok try a fill.the reasoning behind this is that the drier element goes faulty and gives a false reading to the control pcb.if this is successful ,replace the drier element.another option if any of that doesn`t work ,check carbon motor brushes.
Jul 22, 2014 | Washing Machines
Mtd4 mistral
Underneath where the motor is,, there is a locking mechanism, which is operated by a cable connected too the lid, check cable hasn't snapped or come off,, it's adjustable also,, may just need adjusting
Jun 17, 2013 | Creda S202pw Debonair Spin Dryer Drier 9lb...
Remplacement drier a/c suzuki grand vitara
you need a machine to remove the freon gas to change any part off the ac system so the gas doesn't go into the air and your lungs
Aug 15, 2012 | Cars & Trucks
Hello My drier has stoppped warming the clothes, it is still turning - but no heat. Whirlpool Gold Model no 3RLEC 864 6K 08 Thanks Rheinallt Williams
dear Rheinallt , the problem is one of two things either the thermostat or the element itself . Try the drier on different heat settings to see if it heats at all . If it does - then its the thermostat . if it doesn`t then it most probably is the element . Depending upon where you live it would probably be more economical to buy a new one .
Aug 13, 2011 | Whirlpool Dryers
Make Frigidaire dryer model Gleq2152es1 is making a loud sqealing noise and the clothes getting hung in top of dryer.
mostly the noise your hearing is the drum running on the side of machine .the baering/bearings have collapsed in your drier . Most driers these days have the bearing encased in the outer drum and i mean molded to the outer drum . You cant replace them and the manufacturer doesn`t really want you to . Sorry about that = looks like a new drier for you .
Aug 13, 2011 | Frigidaire GLEQ2152ES Electric Dryer
I have a maxx 7 sensitive, condenser drier. it won't turn on, have checked fuse, plug, cleaned filter and reservoir but hasn't helped. The power light doesn't even come on anymore
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your drier. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 07, 2011 | Washing Machines
In the back of the drier there is a wiring plastic looking block with a number of wires going into it. As you?re facing the back of the drier looking at that block the terminal on the far left has three...
Often the vibration will loosen the wires, they then become hot and burn off...the block can be replaced... if you cannot buy it from and appliance repair site then check a local electrical supply. It really should not be that hard to replace it...
The burnt wires will need to be cut back and reattached...
You may even want to buy a new cord and use that to reattach to the block...
Here is a tip that will help you with changing your dryerplug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
26 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
