Question about Brother DCP-7020 All-In-One Laser Printer
Printing not dark and bold.
How do I get darker and bolder printing? I tried changing the Printing Preferences to HQ 1200 DPI from 600 DPI but did not notice any difference.
I just bought a refurbished model from Staples.
Well, I can tell you that on Microsoft's Notepad application, I changed the default font to Courier >Bold< and that seemed to help the problem for that application. Font looks like a normal font when printed on the DCP-7020 now. However this is, admittedly, a very limited solution, sort of last-ditch workaround. Haven't noticed the problem particularly with web pages. You might also try looking at the "Text" option. That helps sometimes..
Posted on Feb 18, 2008
Which laser printer is best for screen/butter prints for extra dark black print outs ?
Dear You can choose any printer having printing resolution more than 600 DPI. For screen printing the jobbers prefer for resolution from 300 DPI to 600 DPI.
Thanks.
Jan 14, 2015 | Laser Office Equipment & Supplies
Which monono laser printer suits for extra dark printing on butter paper i tried almost. Pl guide
Dear Rajendra
You can choose any laser printer with printing resolution 600-1200 dpi. According to the type of toner non-magnetic toner will perform the best and lasts long without deterioration of its color. Before buying the choosed model you may download the driver and verify the setting procedures to confirm. Also if you are going for prepare for master the driver setting should have option for lower the dpi up to 300 , in case of screen print application. Few manfs are hp,canon used magnetic toner where as samsung,brother,konica minolata etc. are used non-magnetic toner on their low/ middle segment.
Thanks.
Jan 12, 2015 | Laser Office Equipment & Supplies
300 dpi print
go to the cannon website and check their support/downloads
Dec 23, 2013 | Canon LASER SHOT LBP-2900 Printer
Dell 1320c is giving faded printing in both color and black. I've replaced two toner cartridges, tried to 'bleed' the cartirdge by printing 20 copies, toner save is turned off and there is no...
After you click print, and just before you print, go to your 'printing preferences' or 'print settings' in the popup window. From there, cycle through the tabs, and ensure that 'print quality' is NOT at draft and IS on normal or high quality. Alternatively, you change the 'print resolution' in this window, if the option is available. Resolution is usually given in 'dpi' so choose the highest 'dpi' value. This should hopefully give you darker prints
Aug 26, 2011 | Dell 1320c Laser Printer
When i print a pen and ink drawing it prints very lightly
Try changing the color quality of your printing under your printing preferences to best to get darker prints.
You might have set your printing quality to fast draft or fast normal.
If you do not know how to go to your printing preferences. Follow these steps.
1. Go to your Printers and Faxes(XP), Printers(Vista), Devices and Printers(Win7) 2. Right Click on Your Printer Icon 3. Click on Printing Preferences 4. On Print Quality, Choose Best. 5. Under Features -- Check the box for Print in Maximum DPI.
I hope this one helps. :)
Feb 04, 2011 | HP Deskjet 5440 InkJet Photo Printer
How do I adjust the darkness of the printing, it is currently set at 2 out of 4 darkness?
You will need to follow below process.
Print quality settings always affects on print resolution and toner usage.
to change print quality setting:
1. go to Start/settings/control panel/printers
2. then go to printer's properties.
3. go to paper/quality TAB. and select the setting that you want to use. you will get following options.
a) 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
b) 1200 dpi effective output quality: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
c) 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology (REt) for improved text. (this is what you may need to get)
d) Economode: this settings use less toner of your printer. This is useful for mostly draft printings. You can turn this button on freely of other printing-quality settings.
Select the needed settings. Test a print.
And if it is perfect you wont be charge to give recommendation...lol
Aug 12, 2009 | Samsung SRP 350 Thermal Printer
Can't figure out how to adjust darkness/tone for printer output
Below you can see a step by step procedure on how to change the print quality of your work....you need to make test printouts in order for you to see the results....at the end there is a link to the manual for your printer...GOOD LUCK!!!
Print-quality settings affect print resolution and toner usage.
Use the following procedure to change print-quality settings:
1. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
2. On the Paper/Quality tab or the Finishing tab (the Paper Type/Quality tab for some Mac drivers),
select the print quality setting you want to use. The following options are available:
● 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
● 1200 dpi effective output quality: This setting provides 1200 dpi effective output quality
using FastRes 1200.
● 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology
● EconoMode: Text is printed using less toner. This setting is useful when you are printing
drafts. You can turn on this option independently of other print-quality settings.
Manual
Apr 13, 2009 | Office Equipment & Supplies
How do i align my printer, it's printing blurry
Setting the Alignment:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
Apr 01, 2009 | Brother DCP-120C All-In-One InkJet Printer
Cant make prints lighter or darker
There are two ways to do this. One is to change settings in whatever application your are using. Increase your font size or bold your font (if you're talking about a document.)
The other way is to change your printer properties. Go to your printing preferences (from your print dialog or from Start->Printers and Faxes->right click on Lexmark 5400 Series->select Printing Preferences) and increase your Print Quality.
Steve
Jan 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Problem printing
The toner cartridge roller may be defective or there are outside light going inside the printer, causing the bands.
Mar 05, 2008 | HP LaserJet 1018 Printer
Brother DCP-7020 All-In-One Laser Printer Logo
157 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
