Question about Lexmark X4270 All-In-One InkJet Printer
Error code 1200 is showing?? help!!
We decided to buy a new printer, the ink for this is very expensise, and honestly we have this for about 10 years. thanks so much.
Posted on Oct 01, 2009
  • Lexmark Expert
  • 228 Answers
The error 1200 indicates that the cartridge carrier is stuck inside the printer. Please follow the steps given below:
1. Unplug all cables from the back of the printer.
2. Open the front cover and look above the steel rod. You should see a black belt with rubber teeth on it. (On some models, the cartridge access is very small, but the belt should still be visible.)
3. Take the top part of the belt and move it gently to the right. The cartridges should come towards the center.
4. If the cartridges will not move, tilt the printer on its back and try moving the belt again.
5. If it still will not move, try putting your finger inside the area where the cartridges are stuck (with the printer still on its back), and push them firmly against the cartridge carrier holder while you move the belt with your other hand.
6. Once the cartridges are in the middle, snap them firmly into the cartridge carrier. Note: Make sure that these cartridges are the correct models for your printer. Once the cartridges are seated properly, they should not become loose inside the carrier.
7. Plug all the connections back in and power the printer up.
8. Open the front cover again to see if the cartridges slide to the center.
You should then try to self-test the printer. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in and follow these steps:
Next, try this printer self-test by following the steps given below:
1. Press the "Copy" button once.
2. Press the "Options" button 11 times until the screen reads "Maintenance."
3. Press the "Left Arrow(-)" button until the screen reads "Maintenance: Self Test."
4. Press "Select."
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
  • Roopesh S
    Roopesh S Oct 01, 2009
    4. Press "Select."
What does code: H4-00 mean
The H4-00 is a low temp error in the fuser. This can normally be reset by doing the following at the machine:
On the button panel hit
pound, star, C, star
then enter 14, hit start, then execute on the screen.
This should clear any one-off errors
www.equipmybiz.com EquipMyBiz
Aug 04, 2014 | Sharp MX-4101N Multifunction Printer Color...
Service error 140.10 transport motor
This is a generic error message that can be recorded for a wide variety of problems. Basically, any time the Report Server has problems initiating an application it will record this message along with:
- Application name (i.e. WindowsService_21, WindowsService_13, WindowsService_8)
- Error description (and that can vary widely). Examples: "The endpoint cannot be created.", "The report server has encountered a configuration errorr", etc.
For more help visit cbrtechsolutions
Mar 12, 2014 | Lexmark MS410DN Laser Printer - Monochrome...
THE UNIT SHOWS ERROR CODE 1200
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
You can check this article on how to solve that problem: http://bit.ly/XypLZK
Nov 11, 2012 | Lexmark F4270 Plain Paper Inkjet Fax
Eroor 1200 is showing
The 1200 error indicates that either the cartridge/s is not properly installed or snapped in the cartridge carrier, the encoder strip (transparent strip behind the cartridge carrier) is out of place or something is blocking the cartridge carrier's path. This article 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One will help you identify and resolve the issue.
May 30, 2011 | Lexmark X4270 All-In-One InkJet Printer
Printer shows error 1200. how do I fix?
The error 1200 is caused by the cartridge carrier getting stalled. That can be due to several causes. Here's an article in the Lexmark website to guide you to identify and, hopefully, resolve the problem. Just click on this link: http://bit.ly/9QxkWP. Hope this helps. If you need more assistance, place a comment so I can get back to this. Thanks.
Apr 13, 2010 | Lexmark X4270 All-In-One InkJet Printer
My lexmark X4250 is showing an error code 1200.
It means that you have a paper jammed somewhere in the machine. Check in all the places where the paper moves for some scrap of paper that may be covering a sensor.
Aug 22, 2009 | Lexmark X4250 All-In-One InkJet Printer
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Lexmark X4270 All-In-One InkJet Printer Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
