The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
If you need to buy a card reader, they can be had for a minimal cost at just about any electronics or office-supply store.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
You cannot create new folders on an SD card and copy images to them, as the camera will not recognise them, since they were not create in the camera. Copy the entire contents of the card to a folder on your HDD, then format the card in the camera.
I've had some S3000's become gimmicy when connecting to a computer. The easiest way I've found to get photos off of the camera is to use a card reader connected to your computers USB.
Sandisc makes cards in various speeds or "classes". For videos, it's best to use a class 6 or better card. Sounds like your new 8GB card is a class 4 or lower.
If the pictures are in the camera's internal memory instead of in the memory card, you need to remove the card from the camera before trying to transfer via the USB lead. When the card is in the camera, the computer can only see the contents of the card.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
When looking for a sound card it's really up to you what kind of sound card you want. As long as you have a PCI slot available on your CPU board you will be able to put in a sound card. I would recommend getting a creative soundcard they are the best that I know of.
The S3000 has a 512MB limit according to Fuji. Ther is also no firmware upgrade to address this issue. However I loaded a 1GB Olympus M type card into th S3000, which was pre-fornatted and worked straight away. After putting the card into the reader in my laptop, and then returning to the camera, the camera identified the card as not initialized. I tried to format the card in the camera but this didn't work.
To fix this I connected the camera to the computer using the USB cable located the camera card via My Computer, left clicked on and did a quick format in FAT (FAT16). After this the camera read the card and indicated 1305 frames available at 3M.
What is the question?
