Question about Moultrie MFH-DGS-200 Digital Camera
Camera takes flash pictures continuosly at nite as soon as the set interval is up. Works fine in daylight.
2 Suggested Answers
  • 68 Answers
SOURCE: CAMERA WILL NOT FLASH AT NITE
DSX-1 interface. Pinouts for each of the RJ-48C jacks are RCV to the DSX-1 from the span on pins 1 and 2, .... DSX-1 Drop. RJ-48 C, terminal blocks. Power Supply Options ... HiGAINMINI SHELF. INPUT: WITH PS 100/120 VAC. 1.0A 50/60 Hz
Posted on Sep 10, 2009
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Dec 28, 2010 | Fuji FinePix A330 Digital Camera
When i take a picture with the flash, it has a yellow tint to it. Why?
Most likely your white balance setting needs to be adjusted. You didn't specify the model of your camera, so I can't tell you exactly how to change it (your manual should say).
Your camera should have several settings:
"A" or "Auto"
"Daylight/Sun"
"Tungsten" or "Indoors" or "Incandescent"
"Fluorescent"
and possibly also:
"Flash"
"Cloudy" or "Shade"
When taking flash pictures, the "Flash" setting should be best. If you don't have a flash setting, then "Daylight" or "Sun" will be the best.
Human eyes adjust quickly and easily to different colors of light, but cameras see light as it is, so indoor light will look yellow, outside bluish, fluorescent greenish, etc. So digital cameras shift the colors in the image to try to make white objects appear white like they would to your eye. But sometimes they mess up and don't get it quite right. That is where the manual white balance settings come in. If you play with these settings, then you will find you can improve the color quality of many of your pictures.
Dec 03, 2010 | Cameras
Yashica ez digital 6032- 6 mp camera.. i got one sparingly used yashica camera... with above spec... which shows trouble when taking stil pictures outdoors... indoor pictures and video indoors n outdoors...
i am using yashica ez digital 6032 camera but while using SD card of 4GB memory, it is not working. it is asking to format. Pl. help me regarding this problem. Shall i format the camera?
Apr 27, 2010 | Cameras
Pictures are pixilated and outside pictures look like negatives.
First try to reset the camera: take out the battery and press the reset switch for about 3 seconds. Reinsert the battery and take a picture. If it works in the dark conditions (with flash) and doesn't in the daylight then I would suspect the problem with CCD sensor.
Jul 18, 2009 | HP Photosmart R707 Digital Camera
Camera takes white pictures in daylight
Sounds like over exposure due to the shutter not closing all the way. test video out. should work fine. shutter mechanism will need cleaning
Apr 25, 2009 | Canon PowerShot A630 Digital Camera
Flash wont come on
If your flash is failing, it will require service by Canon.
Dec 24, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
AWB problem on 555
I noted that situation, but was my fault because i've been using Bulb or tungsten in outdoor pictures...!!! AWB works fine most of the cases except in some indoors where i have to use manual WB. Please be aware that if you have enough indoor light could be a good idea to disable the flash, try and error......
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Moultrie MFH-DGS-200 Digital Camera Logo
21 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
