Question about RCA 14F512T 14" TV
"No Signal" Keeps Flashing on the Screen
After I set up the TV and scan for available channels, "no signal" keeps flashing on the screen at random times, even on a channel where there is a signal. Can this be fixed?
  • 482 Answers
Try a bigger and or better antanna. if you are not on anykind of cable or sattalight
Posted on Dec 20, 2007
I would suspect you have a weak or intermittent source. If it is cable, you may want to have them check it for you. If you are using an antenna, you will want to get a better one or at least try a different position.
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
Nov 16, 2013 | AOC L22W898 22 in. LCD TV
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
The TV turns on but cannot find a signal (as has been normal when swictching to HDMI inputs). Usually it takes a second and the Cable or FIOS signal shows on screen. As of today, the images never comes...
Tries tv and cables boxes uplug,replug it back like about an hour later for the tv resetting itself back to the factory setting and those pay boxes updated it softwares.Take the HDMI cable plug it in into another tv HDMI hub.Tv should have signal and work again.
Feb 17, 2011 | InFocus ScreenPlay 61" Rear Projection...
I can not get channels on my vizio hdtv. i have a cable cored hooked up to the tv and i can not get the channels to come on the tv screen. it keeps saying "No Signal!"
You will need to make sure that your cable is connected to the correct input (if more than one) and then enter the Menu and look for a "set up" screen and select "Scan for Digital Channels".
After the scan the TV should be fine.
Jun 14, 2010 | Vizio L32 32 in. LCD HDTV
65" Mitsubishi Projection Television keeps flashing black screen
check your closed caption, long time ago there were 4 cc options. Turn it completely off, that might get rid of it.
Jul 18, 2009 | Televison & Video
Screen shows no signal
HDTV sets are different from the old analog sets.
If your set is showing No Signal or Weak Signal you will have to do the following.
1) Connect an Antenna or Cable to the input on the back.
2) Go into the Channel signal source menu and select either the Air/Antenna or Cable option.
3) Go into the Auto Program Scan menu and SCAN in the channels.
Now you can watch available channels.
Dec 29, 2008 | Polaroid FLM-3732 Television
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Ilo 42" plasma flashing screen
sync signal problems
check audio vedio cable
>If all things is ok check CRT
Dec 02, 2007 | Packard Bell iMedia SL 9553 (P660401806)...
RCA 14F512T 14" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
