Question about HP Officejet Pro L7780 All-In-One InkJet Printer
How do I Try restarting your OS and power cycling your scanner th
My scanner isn't working on the HP 7780. This is a replacement of the exact same one. It worked with the other one.
Says the scanner is being used by another software - nothing else on.
    Novelist:
  • 114 Answers
Try This :
Unplug the USB cable;
Then put the CD in the computer ;
Goto My computer- Right click on Black HP logo - Click on Explore - Open UTIL (Folder)- Open CCC (Folder)- Double Click on UNINSTALLATION L3 file;
If you don't have the Cd Uninstall the software from Add and remove programs
Restart the computer ;
Click on the below given link it will help you download the software :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=2512010&lc=en&cc=us&dlc=en&lang=en&cc=us
Select your OS;
Select the Full feature Driver;
Click on Download ;
Save to your desktop;
and then run the software;
Then while installation select the "Recommended" option and install it;
Try to scan from "HP Solution Center".. "home"
This should resolve your Issue
Regards Soumajit
Posted on Oct 01, 2009
The printer is added but the scanner isn"t
Might be the driver cd not supporting the OS,..down load the full feature drivers from hp site,install it & check..
Oct 04, 2011 | HP LaserJet 3030 All-In-One Printer
I have installed hp scanjet 2400 driver on XP but it is not working. message coming is "No HP Devices have been detected. HP Solution Center Will close now" Kindly help me out as i am unable...
Hi
Try a different cable to connect to the PC.
Try downlading updates and security patches from here.
If these don't work, power off the scanner > disconnect the connection cable > uninstall all components of the HP Programs in Add or Remove programs > restart the computer > reinstall the scanner drivers and programs > restart the computer > power on the scanner > reconnect the cable > test again.
If none of this works, the device may be faulty.
I hope this helps.
Aug 27, 2011 | HP ScanJet 2400 Flatbed Scanner
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
I have an hp digital copier, stand alone, not connected to any computer. When I turn the power on the warm up message lasts for a long time. It then tells me there is a scanner failure and will not print....
Hello.
Give this a try (from HP Support):
The Scanner System Failure error occurs if the scanner bulb is not being heated up to the correct temperature or there is some other issue with the scanner hardware. Verify that the scanner bulb is lit.
Power cycle the all-in-one product and see if the error comes back. Perform the steps given below to power cycle your all-in-one product.
1. Shut the computer system off, then disconnect the all-in-one product from the power source. Leave the all-in-one product disconnected from the power source for at least one full minute.
2. Reconnect the power, then restart the computer system.
If it does, take it off of any power strip and plug it directly into a wall power outlet. The power strip may not be supplying enough power to the product. Cold ambient room temperatures may also cause this
error. Try moving the unit to a warmer room and see if the error reoccurs. The unit will need to be serviced if the bulb does not come on.
Perform a semi-full reset by following the steps given below:
Caution: A semi-full reset will reset or clear the following information:
* Return the user settings to the factory defaults
* Delete language and country settings on some models
* Fax logs
* Fax headers
* Fax speed dial information
Hope this helps.
Feb 07, 2010 | HP 610 Color Copier
HP 7780 says "turn power off then on again"
Your scanner assembly is defective, it will cost more to have it replaced than a new printer would cost.
Dec 20, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro 7780 will not scan on Mac Powerbook G4
YOU WILL NEED DRIVERS FOR THAT DEVICE.
WWW.HP.COM/MAC
HP OFFICEJET PRO DRIVERS MAC 7780
OR
HP OFFICEJET PRO 7780 MAC DRIVERS
OR
HP OFFICEJET PRO 7780 DRIVERS
AND
CONTROL PANAL GO INTO NETWORKING AND SHARING FOLDER
PRINTING SHARING, OR PROPERTIES SETTING NEED TO BE CHANGED
DOES THE SYSTEM SUPPORT WIFI
MAKE SURE THAT THE ANTIVURAS PROGRAM AND FIREWALL IS HAS STOPPED YOU SCANNER TO COMMUNICATE WITH THE MACHINE, JUST SOME FINE TUNNING IN THE FIRE WALL MAYBE ALL IT IS.
ROD
Feb 09, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Mac and hp 7780
I had the exact same problem but never could get my Mac to work wirelessly with my 7780 even though the box said it was wireless and worked with OSX....false advertising.  Enough of the problem though.
I set up my printer through my Airport Extreme network.  That solution worked sporadically.  I would get error messages that the computer could not open the printer.  I found clicking the "pause" print button and then clicking "resume" would often work but needless to say that became a pain.
So, my IT guy set the printer up through it's IP address over my airport extreme network.  The printed has worked flawlessly for the last week since this change but.....the fax no longer works and now the scanner takes about 3 minutes per page.
Overall, I have been a die hard HP fan for years but after the nightmares with the L7780, I will NEVER use another HP product.  The item cost me about $459 but I have lost or spent over $5,000 in diminished productivity and IT charges and it STILL DOESN'T WORK AS ADVERTISED!
Jul 10, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet all-in-one
This issue seems with the scanner mechanism of the all-in-one. Once try to make a copy and check the result, of it still says scanner failure, then connect the all-in-one directly to walloutlet and then power cycle the all-in-one and then reset.
May 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Does not detect
First of all you have to uninstall your scanner software completely and to restart your computer with the scanner disconnected.
Reboot
install the scanner software exactly !!! as hp has recommended.
Reboot.
If there#s no success: I started in disassembling the scanner:
disconnect from power
solve 2 screws on scanner top
remove the glass cover
move the scanner slegde backwards to start position
assemble the scanner
power on etc.
then the same procedure as every ....
i.e. reinstall your hp scanning software
hope you hare successfull
Apr 23, 2008 | HP ScanJet 3200C Flatbed Scanner
Carraige Jam
maker sure the cleanout station is not stuck..it moves also...dont break it just see if it isn stuck...move the carriage back and forth. put paper in it and turn it back on.....if that does not work..take the paper out ..open the back and roll th big wheels a bit and try again.
Oct 13, 2007 | HP WanProbe V-Series Network Monitoring...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
